depends on how it is supposed to be pronouced. if it is supposed to be pronouced the same as the constelation (oh-ryan) then it is ok as it is completely different.
but then toyota has the ascent (assent) and hyundai has the accent (ack-sent)
  • Replies 115
Posted Images
orion.... what a name meh??
You reckon? I can't really see a market for a diesel Falcon. Territory yes, but not so much the Foulcan. Maybe if they continue to be similar it will be easy to bung an oiler in both.
well actually I do see a market here for Diesel.Europeans have been using the stuff for years.In fact the Majority of cars sold there are Diesels.Both Ford and Holden had better realise whats going on in the world.Diesel is only going to get bigger. The way fuel prices are going large engined sedans on petrol will be completely unaffordable very soon.Diesels use so much less and with the technological advances Diesels have made these days accelerate as good and better than the Petrol engine equivalent. Look at what VW has done? their Diesel cars are quicker than the same car with the petrol engine..Howabout Audi winning Le Mans in a Diesel?
Yes the euros have been driving diesel cars for yers. But then again if fuel was double the price, the roads half the size & the taxation rates even more stupid than they presently are everyone here would probably be driving a 1 litre diesel Fiat something. And hating it. Not sure if you noticed but diesel prices are in lock step with petrol prices - and it is more expensive & less common (in metro areas). Plus you have to stand in the awful black oil slick & get the stinking sh!t all over your hands every time you fill up. Then there is the noise, the lack of a torque band more than 2000rpm wide, the dodgy resale....
Audi winning Le Mans. That is mostly about weak opposition & stupid rules. Like Le Mans has always been, really.
In any case given that Australia has an abundance of gas it makes sense for Ford to build an engine that runs on LPG. Which they do. So maybe less of the is Euro is good and a little more credence to the local engineers who are building the things.
Edited by djr81
:D he's not the one on drugs funky! VE looks like crap! :D
I really like it, does look similar to the BF's in some parts but that's ok, you don't have to go overboard and make a new model look totally different, especially when the BF was such a hit.
Agreed - this new model shits over the VE in the looks department, probably in every other way as well.
On another note, once the V6 has been integrated on the falcons from 2010 onward, guess what the XR6T or G6E Turbo will be having? Yupp.. you guessed it, a twin turbo V6 :D
It will be the same engine from Lincoln MKS that will commence production around 2009.
The V6 Twin Turbo is called " Twin Force "
TwinForce / EcoBoost
A direct-injected, twin-turbocharged version of the all-aluminum Duratec 35 has been developed, producing 430 hp (321 kW) and 400 lb·ft (542 N·m) of torque. The TwinForce 3.5L V6 is intended to deliver the performance (on demand) of a typical large displacement 6.0 L-class V8, with the normal driving (highway) fuel efficiency of a 3.0 L to 4.0 L class V6.[4][5] The engine is also capable of operating on any mix of E85 ethanol and premium gasoline, and made its debut in the Lincoln MKR concept coupe/sedan, introduced at the 2007 North American International Auto Show.
Gasoline direct injection more precisely manages fuel flow into the cylinders, for more efficient combustion and emissions control, when compared to port injection. Twin-turbocharging forces more air into the engine on demand, allowing additional fuel to be injected and burned, producing more power: 118 hp (88 kW) per liter in the case of the TwinForce. Technologies for the twin turbocharging system were developed in cooperation with Volvo Cars, and the gasoline direct injection system is a joint development between Ford and Bosch based on Bosch DFI systems already in production.
At the 2008 NAIAS, Ford introduced a similar gasoline turbocharged direct injected engine family called EcoBoost, scheduled for production starting in 2009.[6] The EcoBoost family is expected to be available as four-cylinder I4 and six-cylinder V6 versions. The 2010 Lincoln MKS is scheduled to kick off EcoBoost production, with a 3.5L V6 version estimated at 340 hp, in mid-2009. The Ford Explorer America and Lincoln MKT concept crossover utility vehicles, which debuted in the 2008 NAIAS, show a similar displacement GTDI EcoBoost engine with up to an an estimated 415 hp.[7] The company eventually plans to equip a half-million cars and trucks annually with turbocharged EcoBoost engines by 2013.
Edited by Barbarian
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
