  • Replies 241
So a stock looking and sounding GT-R with 400 + kw's at the treds....
must be a lie only people in nsw could pull this off.... or maybe its on autosalon's dyno ?
Did someone say that top gear should road test this standard gt-r ?
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/2/#findComment-3652784
Assuming this is legit, this must be up there with Giants BNR32 results. "N1's" (Undoubtedly modified) with greater then stock response, 400rwkw and 10s quarters?
Makes ppl that fit singles, wanting less then 400kw's look like monkeys haahahah.
...Still in shock with a whiff of denial, I am.
Edited by GeeTR
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/2/#findComment-3652796
There are enough subtle things going on in the engine bay to know this is genuine. Go to Vic race tracks to see some of the RPM built GTRs doing there thing and you will be amazed by how quiet the cars are. A result of the in house exhaust development. You see how quick they are and thats a result of the chassis, engine, braking, cooling development that RPM have done on the GTR.
I say hats off to a local workshop wearing the huge expense of development and showing an amazing level of ingenuity. Rather then just slapping a catalogue of Japanese brand names on it and hoping that it works, or assuming that Aus Engineering/Tuning is inferior to Japanese so not worth the bother.
Personally it sux to see the GTRs going so quick becuase i have to admit to myself that deep down i want one :)
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/2/#findComment-3652829
:) 100% :D
I've personally only realised more recently, the insane levels of expense required by shops (So, not just experimenting on various customers "no budget" project car)
The cash equates into nothing more then knowledge to put into another customers car.
People often whinge when shops lock ECU's or don't divulge certain details of setup. "Its my car dammit" they say. Often certain tricks can make or break a setup; differentiate it from the pack. Big shops aren't around to fluff you, they run a business.
What ever they are doing, should be kept tight to their chest.
Respect
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/2/#findComment-3652848
Just put the figures into the dyno comparison tool http://sau.garagespank.com/login.php it's very impressive to say the least.. My car was running race fuel octane with plenty of timing and it still doesnt have anywhere near the down low power...
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/2/#findComment-3653299
The way the dyno operator loads the car up also makes a huge difference to the look of the curve.
I've came to the conclusion that its near impossible to compare a curve in a true sense.
Mine for example during tuning was seeing 225rwkw at 4000rpm with 1bar; a usual shootout mode power run where you'd nail the throttle at 2000rpm and by 4000rpm we would only see 190rwkw.
But none the less this gtr does have it. :thumbsup:
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/2/#findComment-3653309
Check out this engine for area under the curve.
Goes like no other RB we have ever seen!
Sounds like a dream??? photoshop??
I can assure you it is for real!
Hopefully there is more to come so stay tuned...
MORE PIC'S Dammit!!!!!!!!!
Top results!
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/2/#findComment-3653385
Well done Ben...top stuff. Very similar to our 20psi BP98 run at Autosalon Newcastle. You have better down low (i suspect my GT-RS turbo's might be a little laggier than what you have fitted), mines a bit harder midrange but with the same top-end. Good comparo as yours is not finally tuned, ours was ran-in the day before and still with a very safe tune. If someone would like to re-plot our graph over Bens so its easier to look at feel free.
GO THE LOW-MOUNTS!!
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/2/#findComment-3653461
Its a 2.9ltr Joel (same as thread title, RB29) :D
That it is buddy. :P
Mark99 used a destroked rb30 crank with rods and custom pistons in an rb26 block to obtain 2.9ltrs. Very similar result.
Curious if this is how they are also doing it.
150rwkw off the bat at 2600rpm is impressive. Its pretty much the same as my stock rb20det turbo'd rb30det was making without loading the car up prior to starting the power run. With the GT30 with 1bar it doesn't make 150rwkw until 3000rpm if you don't load it up prior. hence my comment of how a car is loaded up makes a huge difference to the look of area under the curve. IMO. :whistling:
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/2/#findComment-3653494
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
