Roy Posted February 20, 2008 Share Posted February 20, 2008 I know one thing for sure. The car has the best inner guards ever ! They alone make it the best GTR in the country (seriously, they are trick) A vote for AUSSIE ENGINEERING!!!! Actually, this car is a pin up for a locally developed GTR. Velo seats, Harrop brakes, V8 Supercar rear wing when at the track....there seems to be a trend to stay away from the normal Japanese parts bin?!?!?!?!?!? Link to comment Share on other sites More sharing options...
Bass Junky Posted February 20, 2008 Share Posted February 20, 2008 Benno = Gandolf with an RB...... Link to comment Share on other sites More sharing options...
Swiper the Fox Posted February 20, 2008 Share Posted February 20, 2008 I know one thing for sure. The car has the best inner guards ever ! They alone make it the best GTR in the country (seriously, they are trick)A vote for AUSSIE ENGINEERING!!!! Actually, this car is a pin up for a locally developed GTR. Velo seats, Harrop brakes, V8 Supercar rear wing when at the track....there seems to be a trend to stay away from the normal Japanese parts bin?!?!?!?!?!? another good one Roy...time after time Croydon's have been sent cars from XXXX (insert well known japanese tuning house) by Autostyle and a few other importers.... only for them to be not only poorly set-up but tuned like a dogs breky. People please take a good note of what has been said here. Yes the Japanese do things well, but just because XXXX has built the car does not mean its the perfect car. In most instances...far from it. A handful of Aussie tuners/builders can do it better than them...id match Racepace/Croydon/Godzilla/Berry-Newman teams against most of what Japan has to offer. We already proved this 15 years ago when Gibson Motorsport was the world leader. Nismo asked them not to bring their cars over to Japan to compete due to the fear of being humiliated. Torque graph Ben ? Link to comment Share on other sites More sharing options...
Sydneykid Posted February 20, 2008 Share Posted February 20, 2008 Nice work Gary. I'm pretty sure a lot of that is wrong though. Except for the last bit.But then the only person who really knows is the big fella. Even then I'm not 100% convinced he even remembers what has been done. Because every time he's done something to the car I've returned to find he's pulled it all apart again. LOL There are only a few options to achieving 2.95 litres, you are limited in the bore size. Being 86 mm standard, 86.5 mm oversize, normally used for ensuring straight and parrallel bores and 87 mm about as big as you want to go. Although there are few alive at 87.5 mm, but that an unnecessary risk that I wouldn't take. From there the stroke is easy to work out, simple high school maths. Once you know the stroke and that it has an RB26 block (tall or short), then the rod length is again a simple subtraction. Getting short custom rods made is expensive and unnecessary as you can more easily and cheaply select the gudgeon pin height. Such that the piston doesn't hit the spark plug. Plus the rod stroke ratio is pretty terrible anyway and shorter rods would just make it worse. Up to here it's just mathematics, the camshaft timing is the real tricky part, it depends on the valve sizes and porting, So my guess (272/280) is simply based on what my past RB30DET power curves look like, hence it is a 100% guess. Lots of fun for all Cheers Gary Link to comment Share on other sites More sharing options...
Swiper the Fox Posted February 20, 2008 Share Posted February 20, 2008 There are only a few options to achieving 2.95 litres, you are limited in the bore size. Being 86 mm standard, 86.5 mm oversize, normally used for ensuring straight and parrallel bores and 87 mm about as big as you want to go. Although there are few alive at 87.5 mm, but that an unnecessary risk that I wouldn't take. From there the stroke is easy to work out, simple high school maths. Once you know the stroke and that it has an RB26 block (tall or short), then the rod length is again a simple subtraction. Getting short custom rods made is expensive and unnecessary as you can more easily and cheaply select the gudgeon pin height. Such that the piston doesn't hit the spark plug. Plus the rod stroke ratio is pretty terrible anyway and shorter rods would just make it worse. Up to here it's just mathematics, the camshaft timing is the real tricky part, it depends on the valve sizes and porting, So my guess (272/280) is simply based on what my past RB30DET power curves look like, hence it is a 100% guess.Lots of fun for all Cheers Gary I reckon you have almost got it sussed...except for the turbo's...even a 2.9 wont bring RS's on like that. Gav's 2.8 is proof of that. Link to comment Share on other sites More sharing options...
VB- Posted February 20, 2008 Share Posted February 20, 2008 (edited) I reckon you have almost got it sussed...except for the turbo's...even a 2.9 wont bring RS's on like that. Gav's 2.8 is proof of that. they may with some clever head work/manifolding im with SK on this one, i cant see it being RB30 based, i rkn RB26 block with a mix-n-match storker kit, with at least one of the 3 components being custom, most lilely pistons or rods. cams would be big, my guess would be around the 256/64 mark, a little smaller than what SK said but with a smooth 900rpm idle, even with the ebst tuning getting cams like that to idle at 900 would be a stretch (i think so anyway, i have nowhere near the experience of SK) i reckon all that low down power and torque is from manifolding and headwork, thats the 'secret' area. so is this gonna be revealed at all anyway, or are we just stabbing in the dark for no reason? c'mon.... at least give us a hint? tell us whose closest to the real deal? please...... Edited February 20, 2008 by VB- Link to comment Share on other sites More sharing options...
RPMGTR Posted February 20, 2008 Author Share Posted February 20, 2008 Hey guys, I really don't mind sharing the shortblock specs, as I'm fairly sure I've posted details on here a while back. Bore is 86mm Stroke is 84mm Rods are SR20 Its a liner/spacer-plate RB26 block (ala OS RB30), 20mm taller than std. cheers, Ben Link to comment Share on other sites More sharing options...
Merli Posted February 20, 2008 Share Posted February 20, 2008 blah blah blahcheers, Ben Soooooooooo............. About that move to Sydney Link to comment Share on other sites More sharing options...
Roy Posted February 20, 2008 Share Posted February 20, 2008 Hey guys,I really don't mind sharing the shortblock specs, as I'm fairly sure I've posted details on here a while back. Bore is 86mm Stroke is 84mm Rods are SR20 Its a liner/spacer-plate RB26 block (ala OS RB30), 20mm taller than std. cheers, Ben Im amazed there is an 86mm bore RB26 block left in the country Link to comment Share on other sites More sharing options...
ferni Posted February 20, 2008 Share Posted February 20, 2008 Soooooooooo............. About that move to Sydney You know, your money is good in Melbourne as well, send your car down here. Because if Ben moves that means I have to as well!! Link to comment Share on other sites More sharing options...
Snowman Posted February 20, 2008 Share Posted February 20, 2008 Its a liner/spacer-plate RB26 block (ala OS RB30), 20mm taller than std. Haha - that was the bit I knew. (Sorry Gary but it wasn't my place to say exactly what was wrong). I also know what the turbo's are unless he changed them again and they aren't GT-RS (although he did test them I'm pretty sure). The one thing I've found with Ben is you take what you think you know to be right and discard it because he seems to get great results by doing things completely different to everyone else. Link to comment Share on other sites More sharing options...
Merli Posted February 20, 2008 Share Posted February 20, 2008 You know, your money is good in Melbourne as well, send your car down here. You're not helping Ban. Link to comment Share on other sites More sharing options...
paulR32gtr Posted February 20, 2008 Share Posted February 20, 2008 (edited) Couldn't be a couple of Borg Warner VGTs? Edited February 20, 2008 by paulR32gtr Link to comment Share on other sites More sharing options...
N1GTR Posted February 20, 2008 Share Posted February 20, 2008 ummm steve. spun bearing.... oily car. remember that day...... teeheee. lol yeah i remember, but i got back out there as the bearing hadnt quite spun yet In the end it didnt spin anyway I thought you would remind me of that day I know one thing for sure. The car has the best inner guards ever ! They alone make it the best GTR in the country (seriously, they are trick) Pics/details please? I reckon you have almost got it sussed...except for the turbo's...even a 2.9 wont bring RS's on like that. Gav's 2.8 is proof of that. Garrett -10's? Link to comment Share on other sites More sharing options...
Swiper the Fox Posted February 20, 2008 Share Posted February 20, 2008 Im amazed there is an 86mm bore RB26 block left in the country its sleeved to 86mm Link to comment Share on other sites More sharing options...
Blitz Posted February 21, 2008 Share Posted February 21, 2008 Mother of god, that dyno graph, its given me a semi. Link to comment Share on other sites More sharing options...
Merli Posted February 22, 2008 Share Posted February 22, 2008 Turbos.... Hmmm................. Wouldn't be some weird Variable Vane jobbies would it? Link to comment Share on other sites More sharing options...
Lithium Posted February 22, 2008 Share Posted February 22, 2008 Wouldn't be some weird Variable Vane jobbies would it? Maybe T517Zs or something of that sort. Link to comment Share on other sites More sharing options...
archie01 Posted February 22, 2008 Share Posted February 22, 2008 Turbos.... Hmmm.................Wouldn't be some weird Variable Vane jobbies would it? No Link to comment Share on other sites More sharing options...
paulR32gtr Posted February 22, 2008 Share Posted February 22, 2008 4 x oil cooled T2's from a 1984 nissan pulsar ET then? 2 x high mount, 2 x low mount! Just tell us!!! hehe Link to comment Share on other sites More sharing options...
