Yes Cerbera zeds don't rev quite as high although mine revs to 8500 compared to a built GTR prob 9500, peak power that day with mine that day and more revs was 438rwkw, although with stock rods and they bent. Cheap motor with mostly OEM stock parts apart from pistons, since used Scat rods and all good.
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3674357
  • Replies 241
Can we please be put out of our misery!! What's in it!!
All i can figure is that it might have a higher compression ratio than most people might think, and high lift but not too crazy duration on the camshaft, mixed together with some careful cam timing; for a nice recipe..... High comp gives good off boost power and would build response more rapidly...
I'm out of ideas, please tell us the answer, we wants to know......
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3679883
Bens been perfecting this recipe for years.... I doubt he will just "kiss and tell"... I know I wouldnt (but DAMN I wish I knew).
Go Race Pace.
Edited by Antimatter
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3680268
  • 3 weeks later...
P Zero Corsas have to be one of the worst tyres i've ever tried. Get some R comps on and you will feel the difference.. lol
Not sure what your smokin dude but they are a R comp tyre, they're not quite up to the standard of RE55S but they are much better than any street tyre out there...
So tell us about your 'experiences' with tyres, which have you tried and which would you recommend???
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3733320
  • 1 month later...
its sleeved to 86mm
if anyone is looking for a full long block everything except for timing belt area covers and cam covers. i still have one sitting here is a virgin r32 gtr block with standard head which came out of a car with 67000kms on it i bought it for a project but ended up using other bits....
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3857538
+ the rest probably. With all other parts needed for the build...
I meant 20k for the engine. I bet the rest is almost 20k too.
this is running a big single on a rb30 block gtr head.
close, except the rb29 is 447KW (612HP) and it's running on pump gas, not race gas
Edited by Tao
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3857598
I'm coming into a bit of money later this year. I just want to know how much I need to set aside. I bet it's approaching $20k
Double it and you might be getting close to the total figure needed to get these results..
But I still doubt it will be enough... :P
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3858027
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
