Ben has tried more than 5 turbo combos on this engine alone, while logging temps and pressures.
You would be amazed at the power some of these little turbos can make.
As far as I know the turbos are off the shelf -5's.
.64 turbine housing.
I'm glad you assume the compressors wont make that much power.....apparently it is actually the turbine that is getting close to the flow limit.
Same turbos on a F355 Ferrari also make over 450kw @ wheels on only 16psi (different dyno).....
My own track car with 2.6 engine and -5's makes over 400kw @ wheels on pump.
This engine is the culmination of 8 years of Race Pace RB development.
It was built as a challenge for a stock appearing/mannered engine to have monster power and response.
In the last 12 months it has seen over 10,000km of road use and various track/tarmac rally events and is still going strong.
I want it!
what a great read this thread was - educating myself on these larger capacity rb's is very interesting & now makes more sense why the r35gtr has gone the route of increasing cc's!
after reading this thread & talking to ben from racepace...he obviously knows his engines.
i may have missed it but is this engine in a gtr with the rb26 head?
john (JFKGTR) - did u get my pm :thumbsup:
  • 3 years later...
  • Replies 241
Hardly something to compare to RPMGTR...your over 60rwkw short.
The thread is about big capacity RB's, he is contributing relevant data regarding a large capacity RB.
Ever heard the term STFU? :thumbsup:
Ever heard the term GFY.
Btw this thread is about RB29 Wow.
Edited by ezy_09s
And people reading about RB29 WOOOOWWWWW are here to say wowww look at the 2.9L go. Its perfectly relevant for someone else to give a comparison to a 3L, so that those reading this thread can make informed decisions about what they want to do with their own cars.
No need to be sour and say 'your 60kw short'. Crap like that is why there are 1000 RB30DETs on the road and only a handful of people willing to share their knowledge and experience.
Reading over this thread again really got me thinking on how Ben managed to get the results he did using pump 98 on such a low boost pressure.
You would be hard pressed even with E85 on a well sorted motor. To do it with 98 is an achievement in itself as the motor would need to be extremely knock resistant.
High(ish) comp with tricky chamber shaping would have a big part to play I think. I know its the package as a whole that makes it work but to achieve peak torque so low in the rev range and keeping it all the way over 8000rpm isnt as simple as a good exhaust/turbo combo etc.
Im sure even with a bigger turbo setup it would still blow anything out of the water response wise.
Anyone with some inside info want to share some knowledge? or is the answer going to be worth $50,000? :)
Seeing as the car with this engine is for sale, I might as well spill some of the 'Ben's secret specs'
Custom billet crankshaft 84mm stroke
Custom titanium rods
Custom forged pistons 86.5mm bore
Custom chamber/port shape
Variable cam timing
12 injectors
Thats the basics, Im sure there are lots more tricks in there.
I was reading about the new version of the HKS Vcam system last night. This is probably old technology for all I know...
http://www.nengun.com/hks/valcon-ii-rb26-v-cam-system
It seems like an easy way to go to get the wide power band without having to engineer your own VVT system. This setup, some step 1 springs and a ported head is looking to be the top end recipe for my next engine.
It's a bad comparison.
Clearly he came here to big note himself (why else would you thread dig)...
Read the 400kw thread for more details if you really wanna get into it.
Please read the thread in 400 kW.
I posted the link to get a reaction. Was not expecting a bad one.
I have no axe to grind, just want to share my experience on the best GTR forum in the world.
I guess the comparison I can make is I spent about $14,500, all work done by others.
I now have close to a brand new motor, new turbos. Surely this is valuable to others.
I had the opportunity to purchase a built bottom end from ben at racepace in 2009 but I missed out by 1 day. It was only advertised for a few days, he had high demand but then he sold racepace from what I heard?
Gasco123 - Greg at pro engines is a good guy as he ended up building my 3ltr and I too had very good results
    • On the compressor side it looks like the best, if your head setup will support doing 100-110lb/min at 30psi-ish boost.   The G45-1350 compressor looks ideally better if you need closer to 40psi for it, given both the G40 1150 and G42 1200 look like they'll be around the 100lb/min mark at 35psi and dropping from there.   Bear in mind the turbine sides are all different between those three turbos, so that COULD be an influencing factor for how they all perform in the real world as well.   Not sure if you've made a conscious decision to only look at Garrett or not, but at least on paper the XRE7169S matches or beats those other three at everything from 30psi up and just going from wheel size alone likely to be at least as responsive as the G40 1150 and seem to behave closer to G42s in terms of turbine flow.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
