lol...where did you hear that you Wally?...im sure that was only in your mind.
Im talking about non-obtrusive, quiet, unasuming, but very powerful stock looking and sounding cars. I hate driving my car...even the small distance from the shed to home (and you know how close that is). This car i could have easily driven around in all bloody day.
i didn't throw that RB30 bottom end in the tip to regret it...it was exactly that...rubbish. :)
lol, ok ok
Shouldnt you be calling the tip for me soon? :(
  • Replies 241
Exactly....it makes 10+psi @ 2500, hence the big torque early.
Some more details:
Crank is a custom billet 12 counterbalance job. Don't try to rev those RB30 cranks too high!
Rods are SR20. Don't sweat the R/S ratio. 1.5-1.65 has proven to be ideal/desirable for a 4 valver in the 1-9000rpm range.
Modern materials and rod/piston designs mean longevity is not an issue, and shorter rod is a stronger,lighter rod.
Pistons are custom.
Camshafts are Nissan OEM.
Turbos are currently Garrett -5's, (about to make way for a very slightly bigger set).
We have now have it tuned at 24lb and it makes 468kw with plenty more through the mid-range.
I'll post a new dynograph when I get a chance.
Lots of sneaky tricks in this one. I probably shouldn't have sold it after all..... :)
cheers,
Garrett -5's and 468kw ??? this must have been on an engine dyno...right? :(
Was the crank originally an RD28?
i thought the limit of -5's was alot less? without being 100% familiar with 'dash fives', are they one specifc turbo, or are there different sizes? last GTR i saw running -5's was an R32, making ~425rwkw on 116 octane, and it appeared there was nothing more to give from the turbo side of things, unless there are bigger -5's?
yes i envy this motor...
its power is like electricity...you cannot see it...you cannot hear it...you cannot smell it...but boy you can feel it.
Dave, Ron Harrop can help you out with a crank...he is in Melbourne.
Edited by DiRTgarage
They wouldn't make that power on pump fuel without some enlargerment. The compressors simply do not flow enough air. Hence why I asked if it was engine dyno'd....since the best engineering shops will only tune this way. Torque can be measured to .1 ft lb which gives a very very good indication of cylinder pressures.
I wouldn't be suprised to see that type of response on a 2.9 from modified -5's, baby cams help aswell
  • 1 month later...
Ben has tried more than 5 turbo combos on this engine alone, while logging temps and pressures.
You would be amazed at the power some of these little turbos can make.
As far as I know the turbos are off the shelf -5's.
.64 turbine housing.
I'm glad you assume the compressors wont make that much power.....apparently it is actually the turbine that is getting close to the flow limit.
Same turbos on a F355 Ferrari also make over 450kw @ wheels on only 16psi (different dyno).....
My own track car with 2.6 engine and -5's makes over 400kw @ wheels on pump.
This engine is the culmination of 8 years of Race Pace RB development.
It was built as a challenge for a stock appearing/mannered engine to have monster power and response.
In the last 12 months it has seen over 10,000km of road use and various track/tarmac rally events and is still going strong.
I want it!
Edited by JFKGTR
Seeing as the car with this engine is for sale, I might as well spill some of the 'Ben's secret specs'
Custom billet crankshaft 84mm stroke
Custom titanium rods
Custom forged pistons 86.5mm bore
Custom chamber/port shape
Variable cam timing
12 injectors
Thats the basics, Im sure there are lots more tricks in there.
Edited by JFKGTR
I cant confirm it - but have heard rumour that the was some deal done too.
Something about soul and sold to the devil. My personal theroy is that he is the devil - or at least the dark son of rajab of RB's
On the subject of secrets - I want to know how he keeps his shirt so clean?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
    • The switch part, is the switch you use to turn the lights on and off in the car.   The test I had was to determine where in the line it is, but on a quick rethink, if it's only blowing when you turn the switch on, then it's the wire from the switch, to the headlight that's got the short. Now it's a case as GTS said, of physically finding the fault. The fault could be:  metal has broken through the loom. Known as a rub through. Places to check: anywhere the wiring has been messed with in the car, particularly firewall grommets if extra cables have been passed through. Check the inner guard linings, you might be rubbing through with a wheel, particularly if the vehicle has been lowered. Also check for anywhere there could be high heat, especially if heat shields are missing. Double check any wiring at the head unit too if someone has messed with the headlight wiring to pick up a feed to dim the headlight at night. You could also just have really old cabling that is literally falling apart, though, this is more likely in Euros than in an old Nissan in my experience.
    • Yeah. I usually go by the torque specs. I forgot that Nissan recommends 1386b sealant on that thread, still can buy it on ebay actually.
    • Umm.... He attached it to his 2021 update post. Don't need the link. It is stored on the forum.
