Ben has tried more than 5 turbo combos on this engine alone, while logging temps and pressures.
You would be amazed at the power some of these little turbos can make.
As far as I know the turbos are off the shelf -5's.
.64 turbine housing.
I'm glad you assume the compressors wont make that much power.....apparently it is actually the turbine that is getting close to the flow limit.
Same turbos on a F355 Ferrari also make over 450kw @ wheels on only 16psi (different dyno).....
My own track car with 2.6 engine and -5's makes over 400kw @ wheels on pump.
This engine is the culmination of 8 years of Race Pace RB development.
It was built as a challenge for a stock appearing/mannered engine to have monster power and response.
In the last 12 months it has seen over 10,000km of road use and various track/tarmac rally events and is still going strong.
I want it!
what a great read this thread was - educating myself on these larger capacity rb's is very interesting & now makes more sense why the r35gtr has gone the route of increasing cc's!
after reading this thread & talking to ben from racepace...he obviously knows his engines.
i may have missed it but is this engine in a gtr with the rb26 head?
john (JFKGTR) - did u get my pm :thumbsup:
  • 3 years later...
  • Replies 241
Hardly something to compare to RPMGTR...your over 60rwkw short.
The thread is about big capacity RB's, he is contributing relevant data regarding a large capacity RB.
Ever heard the term STFU? :thumbsup:
Ever heard the term GFY.
Btw this thread is about RB29 Wow.
Edited by ezy_09s
And people reading about RB29 WOOOOWWWWW are here to say wowww look at the 2.9L go. Its perfectly relevant for someone else to give a comparison to a 3L, so that those reading this thread can make informed decisions about what they want to do with their own cars.
No need to be sour and say 'your 60kw short'. Crap like that is why there are 1000 RB30DETs on the road and only a handful of people willing to share their knowledge and experience.
Reading over this thread again really got me thinking on how Ben managed to get the results he did using pump 98 on such a low boost pressure.
You would be hard pressed even with E85 on a well sorted motor. To do it with 98 is an achievement in itself as the motor would need to be extremely knock resistant.
High(ish) comp with tricky chamber shaping would have a big part to play I think. I know its the package as a whole that makes it work but to achieve peak torque so low in the rev range and keeping it all the way over 8000rpm isnt as simple as a good exhaust/turbo combo etc.
Im sure even with a bigger turbo setup it would still blow anything out of the water response wise.
Anyone with some inside info want to share some knowledge? or is the answer going to be worth $50,000? :)
Seeing as the car with this engine is for sale, I might as well spill some of the 'Ben's secret specs'
Custom billet crankshaft 84mm stroke
Custom titanium rods
Custom forged pistons 86.5mm bore
Custom chamber/port shape
Variable cam timing
12 injectors
Thats the basics, Im sure there are lots more tricks in there.
I was reading about the new version of the HKS Vcam system last night. This is probably old technology for all I know...
http://www.nengun.com/hks/valcon-ii-rb26-v-cam-system
It seems like an easy way to go to get the wide power band without having to engineer your own VVT system. This setup, some step 1 springs and a ported head is looking to be the top end recipe for my next engine.
It's a bad comparison.
Clearly he came here to big note himself (why else would you thread dig)...
Read the 400kw thread for more details if you really wanna get into it.
Please read the thread in 400 kW.
I posted the link to get a reaction. Was not expecting a bad one.
I have no axe to grind, just want to share my experience on the best GTR forum in the world.
I guess the comparison I can make is I spent about $14,500, all work done by others.
I now have close to a brand new motor, new turbos. Surely this is valuable to others.
I had the opportunity to purchase a built bottom end from ben at racepace in 2009 but I missed out by 1 day. It was only advertised for a few days, he had high demand but then he sold racepace from what I heard?
Gasco123 - Greg at pro engines is a good guy as he ended up building my 3ltr and I too had very good results
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
