hi was wondering if anyone has attempted to run stock gtr or gtst bov's venting to atmosphere. just did a whole lot of stuff to the car and for simplicity want an atmo bov, but i have a lot of stock ones sitting here doing crap all.
if they are ok to run atmo, i will weld those flanges on, but otherwise i have to buy a new bov.
turbos are twin gt-ss. any help appreciated
https://www.sau.com.au/forums/topic/206428-stock-gtr-bovs-good-for-atmo/
They leak at idle.
So no, they will not work in ATMO format at all.
ps. ATMO BOV's are a waste, stock ones are good for over 600rwkw (tried and proven).
Without a tune your going to potentially have backfires, stalling, all sorts of drams
standard bov are designed to recirculate on idle, so no it will not work if vented as stated.
just run without a bov if its only a short term fix.
aftermarket bov have a massive spring in them to prevent manifold vacuum from opening them on idle, but it also makes them not as efficient as standard because they have a harder time opening when they do actually need to dump the air.
whats wrong with the one on the car atm jeff??
Its possible to mount a factory GTR valve on the old GTS-t pipe where your current one is and run a plumb back return up into the bottom of the intake pipe.
Yeah, i have RB26 twin BOV's installed with my HR31/RB26 combo :laugh:
Same for R33, very much possible with not a lot of re-work, just move the BOV's to the passenger side and your laughing.
current one is a china power trust copy..
when holding speed it just pops off every 2 seconds, works fine under load but yeah its chewing fuel and knocking a bit by screwing with the a/f. spring is as tight as possible, and it still blows off even at about -10pounds of vacum if i take my foot off. the constant surging type thing occurs when trying to hold 70+kmh and continues under light acceleration until the air is chewing the fuel turbos are making.
i know i can run it back up through to the intake but it is not acheivable by me at home and i would want to run 2 gtr bov's if i was going to plumb it back in.
i was looking at buying a trust type r or something but its a lot of dough when i have 5 bovs sitting here, and was also wondering if there could be a problem with the pressure feed the bov is getting from the manifold
The problem you have is not a BOV issue. sounds like you have compressor surge now you've fitted the larger turbos. replacing the valve is not going to fix the issue.
I was actually wondering if the twins on an RB25 would cause similar surge problems to those that the RB26 suffers from.b
You seriously need to get off the run in tune and do it properly now.
It could well be actually.
RB26's do get a bit of 'shuffle' going on in twin setup with atmo BOV's due to the factory ones being open early and actually stopping the shuffle
i agree, its very similar to what joeys car was doing in your driveway after his turbos went in, but its a bit constant. even if it was the bov, its caused by surging so i dont know why this thread is still going.. i just wanted to see my options and now we have. brad you have pm
when you spend months building a motor that has a lot of custom piping etc, you dont want to spend more time fabbing up something so you can plumb a stupid bov in, you just do the easiest and quickest, trust me
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
