I've started a new job recently which will mean when I'm fully trained I'll have to start at 1.30am. Meaning I have to leave my car alone in a shopping mall car park from 1.30am till 10.30am.
I have a Viper alarm system with immobilizer installed, and it's fully insured, but is there any extra security I can personally do? I heard someone saying they pulled their throttle plug when leaving their car in dodgy places. Is there a fuse or something simple that I can remove and replace easily that will stop the car from moving with doing damage?
Maybe I'm just being paranoid, as it's not a very valuable car to begin with, with quite a serious alarm system installed, but after reading all these theft articles I am a little concerned.
Thanks.
https://www.sau.com.au/forums/topic/206433-extra-security/
try one of those steering wheel locks that needs a key to undo
or put a chain or something through your wheel? just like a bike lock but bigger?
if your working in the shop near where its parked wont you hear your alarm?
if you do, just put your security training to good use
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3652847
All these security measures are good. But still dont stop people from trying... a smashed window and a FUBARed dash is going to be nearly as painful as losing the car.
I know you probably dont want to hear this but a good idea would be leaving the sky at home and trying to find another way to get there. Which i know would be hard since u start at 1.30am... Maybe a cheapo car that u use to work and home only?
or unless since u working at the mall when its shut... park it inside the mall! . that way its locked up... haha it may be a long shot but who knows?
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3652899
i used to work security in a couple of shopping centres. most usually have at least a few carparks that are on camera. maybe find out where they would be at the centre u work at and park there. if the security guys there are ok to just ask them to keep an eye out for u when they patrol. i used to get those kinda requests all the time so i did. i mean it may not work for u but as i said its worth a try
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3657284
Some funny ideas reading this lol, if some1 wants ur car, tints, steering wheel locks and depending on how gud thief is some alarms are all useless. Best wud be a fill switch or 2, not to hard to put in, chuck it in fuse box under bonnet. Iv heard alot of things bout how cars a stolen etc, stil cant believe how to some ppl its so easy. Dont waste money on any locks or nething from autobarn etc, get kill switch or fuel cut, or another car lol
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3682757
park under a bright light. when u leave, pop the boot and rip out the fuel pump or ign fuses.
REMOVE any precous objects from the car, dont give them an excuse to even think about it.
make sure that the alarm warning light is visible to all to see.
and finally, turn the volume and shock sensor up to MAX.. and u "might" be ok
Edited by r33cruiser
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3689748
Excuse my ignorance, but what is a fuel cut and a kill switch? Are they just switches hidden in your car that must be flicked on for the car to run? Can you buy them and install them, or is it just a custom wiring job you do yourself?
Also, how much would one of these cost to install?
Thanks.
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3691280
kill switch is like a master switch, its not an off on flick switch its like a pin with out the pin switch wont work, and depending how you wire it ie, you can use it as a fuel cut switch etc. some race cars have these, incase of accident or something they can pull the pin and then bang engine not goin no more lol switch isnt much cheep autotechnica one it around $10-$20 from memory and a beter bosch one is $30-$60
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3691306
Doesnt matter how much u spend on security, its not going to stop someone trying to steal it.
People steal any cars these days. Skylines to poor people are a wet dream... full of goodies
My advice is if you have to leave your skyline out of sight for even 30mins, you should be expecting the worse.
Buy a shit heap and drive that to work.
Edited by Antone
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3691637
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
