I've started a new job recently which will mean when I'm fully trained I'll have to start at 1.30am. Meaning I have to leave my car alone in a shopping mall car park from 1.30am till 10.30am.
I have a Viper alarm system with immobilizer installed, and it's fully insured, but is there any extra security I can personally do? I heard someone saying they pulled their throttle plug when leaving their car in dodgy places. Is there a fuse or something simple that I can remove and replace easily that will stop the car from moving with doing damage?
Maybe I'm just being paranoid, as it's not a very valuable car to begin with, with quite a serious alarm system installed, but after reading all these theft articles I am a little concerned.
Thanks.
https://www.sau.com.au/forums/topic/206433-extra-security/
try one of those steering wheel locks that needs a key to undo
or put a chain or something through your wheel? just like a bike lock but bigger?
if your working in the shop near where its parked wont you hear your alarm?
if you do, just put your security training to good use
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3652847
All these security measures are good. But still dont stop people from trying... a smashed window and a FUBARed dash is going to be nearly as painful as losing the car.
I know you probably dont want to hear this but a good idea would be leaving the sky at home and trying to find another way to get there. Which i know would be hard since u start at 1.30am... Maybe a cheapo car that u use to work and home only?
or unless since u working at the mall when its shut... park it inside the mall! . that way its locked up... haha it may be a long shot but who knows?
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3652899
i used to work security in a couple of shopping centres. most usually have at least a few carparks that are on camera. maybe find out where they would be at the centre u work at and park there. if the security guys there are ok to just ask them to keep an eye out for u when they patrol. i used to get those kinda requests all the time so i did. i mean it may not work for u but as i said its worth a try
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3657284
Some funny ideas reading this lol, if some1 wants ur car, tints, steering wheel locks and depending on how gud thief is some alarms are all useless. Best wud be a fill switch or 2, not to hard to put in, chuck it in fuse box under bonnet. Iv heard alot of things bout how cars a stolen etc, stil cant believe how to some ppl its so easy. Dont waste money on any locks or nething from autobarn etc, get kill switch or fuel cut, or another car lol
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3682757
park under a bright light. when u leave, pop the boot and rip out the fuel pump or ign fuses.
REMOVE any precous objects from the car, dont give them an excuse to even think about it.
make sure that the alarm warning light is visible to all to see.
and finally, turn the volume and shock sensor up to MAX.. and u "might" be ok
Edited by r33cruiser
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3689748
Excuse my ignorance, but what is a fuel cut and a kill switch? Are they just switches hidden in your car that must be flicked on for the car to run? Can you buy them and install them, or is it just a custom wiring job you do yourself?
Also, how much would one of these cost to install?
Thanks.
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3691280
kill switch is like a master switch, its not an off on flick switch its like a pin with out the pin switch wont work, and depending how you wire it ie, you can use it as a fuel cut switch etc. some race cars have these, incase of accident or something they can pull the pin and then bang engine not goin no more lol switch isnt much cheep autotechnica one it around $10-$20 from memory and a beter bosch one is $30-$60
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3691306
Doesnt matter how much u spend on security, its not going to stop someone trying to steal it.
People steal any cars these days. Skylines to poor people are a wet dream... full of goodies
My advice is if you have to leave your skyline out of sight for even 30mins, you should be expecting the worse.
Buy a shit heap and drive that to work.
Edited by Antone
https://www.sau.com.au/forums/topic/206433-extra-security/#findComment-3691637
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
