tru tru but with a lil bit of work and less than $50 u can make ur can extremly hard/impossible to drive off in. Sure if some1 does break into your car they will probly leave with stereo and you have to deal with broken windows etc, but you can still drive home
flame thrower alarm ftw
Nice, can't say they don't deserve it.
Also, where can I find these kill switches? Been googling them and can't even find info on how they work let alone someone who sells them.
Thanks.
Edited by KezR33
$500 shit box, great for driving on curbs, hitting speed bumps at 120km/h, and playing bumper cars on the freeway (Mate actually did this!!). Also good for parking in dodgy areas, and petrol is cheaper as well.
you would have to either work at the place for a very long time, or live very far away, before you started to save money on fuel considering the $500 initial investment, not to mention insurance, rego, and repairs on a second car
this is a kill switch. basically u connect the battery...THRU this switch. when u turn the switch off. u kill the circuit.
but hide it better than ^^^^this eh.
its basically a "master switch". all the power runs THRU it. and when u turn it off it breaks the circuit. hence no power
Edited by r33cruiser
yea some are like that, most i have seen they just pull out, like a key, mount one in your fuse box under bonnet and when you park somewhere dodgy jus pop the hood pull the pin/key and walk away.
ps. That flamethrower alarm.... haha that would be awesome haha
autobarn,
switch,relay and terminals.
i actually got the swtches and relays form jaycar on logan road at underwood...
im actually half way thru doing this now... i started it yesterday but i forgot to bring my crimpers home from work so i can finish it... DAMMIT!!!
all ive used is
2 x 4-Pole relays (with bases and relay clips)
2 x small red switches
1 x small black push button
small strip of din rail
and some multi-core cable from work
ive wired it up as such so that to start the car... there is a main switch (1) that must always remain on (unless u never wanna start the car) :D another switch (2) that must remain on... and a push button (3) that is used to allow the car to start... if (2) is not switched in the on position then pressing (3) wont allow the realys to hold in and the car cannot be started... but if (2) is in the on position, then by pressing (3) the relays will latch closed, allowing the car to be started...
im using the relays to cut some of the wires to the ecu...
also, being an electrician has helped me... lol
ill post some of the photos ive taken so far later on today... im on my laptop atm and they're on me other computer...
some photots so far as promised...
Button and Switches
Completed Wiring of 4-Pole Relays
ill keep taking photos of this installation and ill post them all up on here with a description on parts and how to install once completed...
Edited by gumflapper
all ive used is
ive wired it up as such so that to start the car... there is a main switch (1) that must always remain on (unless u never wanna start the car) :) another switch (2) that must remain on... and a push button (3) that is used to allow the car to start... if (2) is not switched in the on position then pressing (3) wont allow the realys to hold in and the car cannot be started... but if (2) is in the on position, then by pressing (3) the relays will latch closed, allowing the car to be started...
nice work, I did something similar minus the extra switches, out of curiosity which wires did you break from the ecu? I ended up doing the fuel pump relay but wanted to kill the ignition or afm but couldnt find the right wires I tried a couple (using ecu pinout diagram) but got annoyed at cutting wires and the engine still able to run. I also wired mine so that the relays can only be energised once the alarm is turned off and the ignition turned on and when the car is turned off the relays unlatch
Edited by SevenAngryPenguins
  • 3 weeks later...
hey does anyone use wheel clamps here? are they any good? I'll do anything to prevent my car getting stolen... I wake up in the middle of the night everytime I hear something that sounds like my car!
do you know where I can get one for a good price???
