Items located in wetherill park sydney pick up is preferred but can post at buyers expense
all prices are negotiable but only serious buyers please......
Item: R33 Steering column complete with ignition barrel and key
Age: R33 lolz 93 - 97 *shrugs*
Condition: deployed airbag column and ignition are fine
Price: $175 ONO
To Fit: (What car) R33 skyline
Contact: as above
Comments: ignition barrell alone will set u back $125 at a wrecking yard and even more from nissan....
Edited by punisher6942
kmon ppl need this stuff gone its taking up room in my already cluttered up garage..... feel free to throw offers my way..... all REASONABLE offers will be considered
give ya $250 for the headlights if in good condition and need a bonnet to if ya no anyone
Edited by WebR33
pink sticker AFM and no not willing to swap for a Q45 AFM as i have a working rb25 AFM on my car and this one is a new AFM that i do not need..... also once i have finished engine work on my skyline with new computer i will be running map sensor instead of AFM
  • 1 month later...
  • 3 weeks later...
  • 3 months later...
  • 4 weeks later...
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
