So, I decided a few weeks ago to paint my brembo brakes on my GTR. They were all chipped due to stones, it is a 1996 after all. The last 2 years on NZ roads probably did more damage then it's entire life in Japan :)
To begin, mask off everything, and wash down the calipers with hot soapy water.
You'll need some Brembo stencils. Any shop that makes decals will be able to do this for you.
Paint Stripper
Brembo Stencils
After the first application of the stipper
You may need to apply the stripper several times to clean off the factory paint.
After all the paint is off, sand back the calipers with 400 grit wet and dry
FRONT
REAR
You can either use hi temp paint or caliper paint. I've gone with a metallic charcoal. 2 coats should do the trick
FRONT
REAR
Important !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
LET THE PAINT CURE FOR A FEW DAYS BEFORE YOU PROCEED
The stencil may damage the paint if you don't
Attach the mask
Peel back the top protection of the mask.
Ready to spray the logo
FRONT
REAR
About 3 coats are nessary as the metallic charcoal is quite dark. Hi Temp White
You can apply a clear coat for a more glossy finish and extra protection.
FRONT
REAR
It takes a few days for the paint to cure properly so, best to avoid driving for a few days if you can.
https://www.sau.com.au/forums/topic/206478-caliper-painting-guide-brembo/
That is really cool. Where did u get the BREMBO stencils from? That would be a ricers dream, fake brembos!! Can you get NISSAN ones as well?
Any shop that can make decals will be able to make this stencil. Most signwriters that use vinyal cut lettering etc. I got a local signwriter to make them for me.
Thanks
  • 1 month later...
brembo's have very tough coatings and undercoats - paint stripper is a must on them
if you can get a good shot of the brembo writing in a jpg form, convert to vector graphics format its easy to get any sticker/vinyl shop to make them
  • 1 year later...
how long does this take in total (hours labour) and where can you find these high temp paints and clear coats from??
thanks
http://www.skylinesaustralia.com/forums/Pa...ers-t97215.html
This thread has est. time and where to purchase paints etc. :/
thanks
took around 2 hours per wheel , including preptime.
The whole project took a few days because it's important to let the paint cure
I'm actually contemplating doing mine at the moment... Want to go yellow just for something different. Any particular paint brand you would recommend? All I have been told is look for the Engine type paint (obviously for heat purposes)...
  • 1 month later...
don't u need to take the caliper off? it's reli cool
1) I tried and i couldn't , too hard.
2) I had just bled the entire brak system and changed all fluids about a month ealier to this project and did not want to go through it all again :P
Looking very nice... But one question, If you went to all that effort why did you choose not to go with a different colour perhaps?
I think the dark suits the car. It's a white GTR, if i'd made it anything else like blue, red, or yellow you'll just look like a douche :)
It's personal preference I guess.
This project was more about restoring the Brembo's to the orginal state as oppossed to pimping it out.
If your car is yellow then the yellow might suit... personally I think anything apart from black or grey gives off a rice boy racer vibe and gets you the wrong kind of attention :ermm:
Get good quality spay paint. Doesn't have to be hi-temp nessesarily. If you just drive around the city and motorways the acutall calipers don't get that hot. Just amke sure to cure it properly before taking it out for a drive. otherwise all that hard work will be ruined
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
