Hey every,
i've done 5,000km since my rebuild...
having a dyno done i only recieved 155 RWHP @ 4500rpm... stopped it early due to fuel pump was dead!!
dyno gave me a reading of heading to 16:1 AFR near 5k RPM
lucky i got forgies in caught it early.. so it wouldnt kill this engine toooo!!
and yeah what made me take it in... is coz it made no power at all, culdnt spin the wheels or jack!
so i got this bosch 040 pump fitted, drove away and she throw me side ways 1st, 2nd n nearly 3rd!
problem is, i can be gunning it... hit the limiter hard 'for like 5secs' n then change gears n it major backfires
n then sounds to missfiring 'WRX sound ' ? or is it over fueling on the limiter coz the inigition??
i got new spitfire coilpacks aswell!!
so yeah anyways i took her for a ride last nite, was going good.. n then took off from the lights n not much power again.. like the fuel pump
problem..?!?!
thinking it was the CRAP GFB manual el-cheapo boost controller i drilled the whole out abit... erm seemed to lower my boost n fkn seems to take ages to spool up now! n the car just makes heaps of noise n speed doesnt go around as shabby as it did n does sometimes!!
WTB my old engine power back =(
any1 had simarly troubles? or any ideas?
should i get ECU? over fueling now? =(
Edited by Mr_GaZZa
https://www.sau.com.au/forums/topic/206499-gts-t/
hey mate,
thanks for the reply... i fort it could be to much fuel now.. stock injectors but ?!
yeah got a boost gauge, its about 10PSI.
until i drilled out the manual boost controller hole a lil n dropped it abit, now takes a while to boost up.
any1 else can confirm its running to rich maybe..
if so i'll get a ecu and a tune!
Thanks
https://www.sau.com.au/forums/topic/206499-gts-t/#findComment-3653001
get another cheap boost controller and don't drill shit.
what is the drilling supposed to do?
what exactly did you drill?
:thumbsup:
hey guys..
driving to work dismorning, after screwing down the key in the manual boost controller a fair bit...
aftermarket boost gauge shows 9-10psi,
coz yestaday arvo i was loosened it majorly... coz i drilled the small hole that flows into the controler 'IN SIDE'
only a drill-bit that was a little bigger in diameter... thinking that may of cause my problems cause i
'read the manual, and said it can cause wierd crap 'surging' n you might need to make it a little larger in diameter 'so i did'.
but driving to work dismorning, i received lots of power, no lag or delay. didnt even surge!!
think i need a ECU to fine tune this mo-foe
any1 have any comments on Greddy E manage units?
and wheres can i get this tuned in PERTH??
BTW mods are as below;
FORGED Melie Pistons/Shells n Gaskets Spitfire Coilpacks Stock Camshafts Boosted to 10PSI bosch 040 Fuel pump Front Mount Intercooler GFB Boost Controller HKS replica SSQ BOV HKS Super Flower Pod Fliter HSD Full Adjustable coilovers HKS replica SSQ BOV 3 n 1/2" Stainless Cat Back With 7 n 1/2 Stainless Inch Muffler Twin Plate H/duty Clutch
https://www.sau.com.au/forums/topic/206499-gts-t/#findComment-3653420
Wat tha?
well theres only a few ways to determine if your car is running okay.
1. just never give it any and then you wont find any major fueling/boost or inigition problems
2. take it out and give it a bit and fault find < against componets and search for possiable causes
3. waste money on dynos, and pay for them to guess and point their finger at things.
the only real way i you can personally feel/find a difference in performance, is drive it
in different conditions... OMG?!
and by the way... i treat my car and engine probably alot better then most others on here.
serviced every 5,000km oil and filter. gets all new geniue parts or aftermarket
equilient or better! only use 98RON BP fuel also!!
gets full clean / wax / polish every weekend.
but yeah, away from that? anyone rekon ECU / AFM meter cant handle it?
and anyone got any experience with the GREDDY E MANAGE?
P.S sorry about the spelling... will try and improve on!
*ADDED*
PROBLEM - SURGING / JUST REVING N ALL NOISE?!
uses major fuel when under-load...
ECU? CAS? AFM?
Edited by Mr_GaZZa
https://www.sau.com.au/forums/topic/206499-gts-t/#findComment-3653735
just leting you know that doing this will reduce the life of your engine by a significant amount.
Hey homeboy!!
did you miss this?
Surely this is the problem!! :whistling:
https://www.sau.com.au/forums/topic/206499-gts-t/#findComment-3653802
Well at least it will look nice and pretty on the back of a tow truck..
I don't call lots of mods and no form of engine management "treating my car well"
https://www.sau.com.au/forums/topic/206499-gts-t/#findComment-3653820
omg guys... its not like i sit on rev limiter?? !!!
=/ SIGH... i think you've totaly missing the point of what happens, just someone told me its over fueling..
and by the way, limiter is there to stop u doing damage LOL if your not riding it all day 'drifting' ect
awww u rekon its the ATMO BOV..
haha it stalls it time to time, but seriously? was more so thinking ECU...
thanks GTST
will try stocker 2nite
https://www.sau.com.au/forums/topic/206499-gts-t/#findComment-3653847
No the limiter is to protect the car from knobbos who dont know when to change gear.. It still does damage.. just not as much as over revving
Edited by MotoMan
https://www.sau.com.au/forums/topic/206499-gts-t/#findComment-3653853
wooohooo
okay? so now its ECU and not treating my car right... by running a lil 2-3psi increase with
fuel and stock ecu? no one told me thats abusing a RB25DET?
kk thanks for the advice, i'll take that as + 1 for getting a new ecu
P.S mate my skyline wont be on a tow truck... =/ scarcasim much here?
https://www.sau.com.au/forums/topic/206499-gts-t/#findComment-3653869
2-3psi increase..
BOV
3 1/2 catback with 7 1/2 tip
FMIC
more than enough to make your car run like crap..
And i certainly wouldnt be doing any regular rev limiter action without some form of engine management
p.s. No sarcasm.. i honestly think you are a knob
Edited by MotoMan
https://www.sau.com.au/forums/topic/206499-gts-t/#findComment-3653877
ok thanks motoman,
i see where your coming from, maybe i've described my problem badly / limiter.. k n 5secs is prob more so 1s!!
i thinks i need some sort of ECU too
extra fuel and air... maybe it cant handle it, hence when shift backfires?
any1 reccomend E-manage ultimate?
https://www.sau.com.au/forums/topic/206499-gts-t/#findComment-3653901
    • Goddam! Thats the dream, neo heads seem hard to come by these days though, best I've seen is $2-3k or there's a full motor for $7k atm
    • Cheers for the input, 450kw on poncams is impressive! I assumed you'd need 264 or 272 for that power level, good to know you don't need to rev that high to hit it, just don't want to buy the cams etc then find out the hydraulic lifters suck haha The box will be getting reconditioned too, possibly an aftermarket gearset if it turns out they're toast, cheers I'll keep that in mind
    • I think definitely get a manual oil pressure gauge on it then. Double check if it's really dropping pressure that low.
    • yes sorry i should of spoke better, all sensors are grounded into their specific homes in the ecu, the ecu is then grounded to the chassis itself along with the EFI relay.
    • I'll check the wiring plan tomorrow. Now when you say ALL the earth's are to the chassis, is that including the sensor ground from the ECU? Certain items should not be grounded to the car/body/chassis, they should ground back to specific ground pins on the ECU.
