MY car got hooked up to the computer today and this is what they have found,
ignition signal primary,
And in the gearbox, system intialization and turbine sensor can anyone tell me where these are located please
hope someone can help.
can anyone help me
Well, isn't that just pathetic - not a single reply in 17 minutes. What is the world coming to?
Why didn't the person who hooked up the computer tell you what / where they were?
he wasnt sure about them all do you no anything
check that the ignition coil harness earth is connected. check cas. an r34 4 door that had this problem needed a new ign coil, put in splitfires and all was fine. try swapping out with someone nearby if they are generous
d/c the battery overnight or longer, hopefully will reset the tranny ecu. if the problem comes back straight away, there is definitely something wrong in there. if it comes back after a few min or after a drive etc... maybe try mentioning what you had done with it eg overdrive button etc. gearbox problems could be quite bad for you
talk to just jap if you bought it recently enough
    • That's convinced me I'll bump up the G30-660 to 770   Any idea if the difference in boost pressure? Cheers
    • When: Saturday 24th of May 2025 - All day Where: Sydney Dragway, Eastern Creek Cost: Varies - Book direct with the GTR Festival Website We will be there on the day with a stand please reach out via our interest form if you wish to help out with the stand. Limited parking will be available in the display area, first in first served with current members getting priority, please register your interest with the link above also. Please post any great photos you take on the day on this thread and we will try use some in our e-mails/website/social media
    • Hey guys so turns out this project is going to be much bigger than I thought haha but I've done some my homework and have done a few panels on my car, but one part I can just not visualise is this. If I do a spot repair and I put filler in a dent for example and sand outside of the repair with 320 grit lets say so the primer can stick as I will only put primer on that repair and the surrounding area and then repaint the whole panel. Don't I need to make sure that I don't put primer on the old clear coat? I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down, it's still shiny. I thought putting paint on clearcoat or primer on clearcoat is a bad idea because it won't stick. So in this scenario it's a bit different to mine but imagine someone doing a spot repair and only painting that small section of repair but the new paint is landing on the old clearcoat. What am I missing?
    • I was immediately reminded that your location is QLD. Sounds like a perfect SEQ business idea.
    • And if you can't drive bigger injectors with peak and hold as low impedance injectors during low pulse width, it's even harder to get a nice clean known amount of fuel.
