As Stated, clearing away all my skyline stuff at the moment.
Have a set of TE37 in 17 inch. 1 rim is damaged (Dented).They are off my skyline r33 gtst. They are genuine bronze colour rim but spray in silver. They also come with AD07 ADVAN NEOVA yokohama tyres. front 60%225x45 (1x slight camber wear and the other quite bad camber wear) Rear 80% 255x40 (No camber wear at all).
Width of front: 8 inch
Width of Rear: 9 Inch
Offset: Unknown stickers is not around. got them on the car for reference( no spacer) should be 35 or 38
Asking Price: $700.
Postage: pickup / To be organised by interstate buyer.
Edited by Giveitall
https://www.sau.com.au/forums/topic/206565-sold/
I will confirm the offset and width tomorrow. will post picture as well.
I am interested, can you confirm the width and offset. I am looking for 8.5" fronts with around +30 offset and 9.5" rears with around _36-38 offset.
https://www.sau.com.au/forums/topic/206565-sold/#findComment-3655269
    • Is the 650rpm idle on the rb25det neo for stock cars only? I've never had my car before and after tuning it to idle at 650rpm when cold. Always idle's cold around 1100rpm, and then drops to about 900-950rpm. I've heard the r33 gtst's idle there.
    • Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $850. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $290. RB26 cams used, excellent condition. $280. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $250. All items located in South Eastern Melbourne. Please PM me if interested.
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
