I've just had my car tuned.. and the injectors were maxed out at 17psi
iam not sure wat size they are.. but iam assuming they are probably
550cc since they've already maxed out with that much boost....
i noe they arent standard as they are purple and not the standard yellow
just wanted to noe.. because the tunes already finished.. is it possible to just
throw in a larger set of injectors and set the injector size in the power fc
and it would justt run.. or would i need a complete re-tune ??
it's an R32 GTR
thanks in advance
Edited by SAM-32R
You can throw a larger set in and possibly set the injector size to get it to the tuners, but ultimately you'll have to get a re-tune and check on the dyno as i think it would run mega rich with larger set in.
Sound like factory ones
550's would be fine for that power level considering stock ones can be pushed to that point.
If you do have after market injectors i would say fuel pump or blocked fuel filter etc etc.
(surely you'd know as you've gotta set-up the injectors in the ECU no?).
nah guys.. they cant be standard cause like i've said they've got the purple tops as opposed to the standard yellows
and cant be fuel pump or fuel filter as they are both brand new items
and on the computer the values currently set on the injector page are 70 and all injectors..
but then while driving and keeping an eye on the duty cycle on 17psi iam hitting 97%
soo that's my problem at the moment
also iam pretty sure they're denso injectors as they have denso on them with the purple tops
Edited by SAM-32R
Well Denso make injectors for just about everyone, so that doesnt help.
In all honesty you dont have 550's if your on 97% duty with 300 @ the treads. Its nowhere near it.
So its either they are around 440 (stock size), or you have something else wrong
New fuel pump doesnt mean a thing if the pressure isnt there, have you checked?
Is the pump getting the correct voltage?
Sam-32R quoted 307 KW at all four
Approx 60-70kw driveline loss
That works out to be approx 500hp at the engine
550cc good for approx 550hp
97% of 550's equals 533hp
Pretty close to 500hp with my calc's
Supprised to see 440cc making 500hp
Have I missed something?
Dude there is no such thing as 70kw loss from AWKW to RWKW a GTR is NOT fulltime 4WD
Its been proven time and time again (there are about 4-5 threads on it now)
There is bugger all difference is rwkw/awkw. Most people are within 10-15kw between the two modes. :D
I agree
I was refering AWKW to engine KW. There is approx 60-70kw lost thru the drive train!
Suggest you READ my previous post again.
Go see the RB26 dyno results threads.
A few users have indeed run the stock GTR injectors to 300rwkw on more than one occasion.
So it would lead me to believe that a 70kw drivetrain loss is far from right. I mean, 20% power loss... Its nothing like that based on other past topics also.
550cc are good for 550hp as the base pressure.
Thats WELL in excess of 310rwkw. Much closer to 360rwkw safely.
To back my theory and a search as suggested, I quote from the guru Sydneykid
Quote-
Yep, but you can't run an engine with injectors at 100%, you need some overhead for acceleration enrichment and changing weather conditions. Around 80% is a good working maximum.
My rule of thumb in a 6 cylinder engine is injector cc's = bhp
444cc's = 444 bhp
divide by 1.34 for kw = 331 kw
subtract 55 rwkw for 2wd losses = 276 rwkw
or subtract 75rwkw for 4wd losses = 256 4wkw
End of quote
Sam-r32 is getting 307 4wkw!!!!
Quote-
444cc's = 444 bhp
End of quote
Buy using the own calculations provided
550cc = 550bhp
/ 1.34 = 410kw
-75 = 335rwkw
So its 30kw more (or nearly 50hp). So, with 335rwkw, 550cc injectors are at 80% DUTY CYCLE as per the calculations for 'most' cars.
So... again, what are you on about mate? I still dont get it.
Even with calculations that back me up, i still dont see where your figures and claims are coming from that 550cc injectors will be maxed out, let alone reaching 80%
550's would NOT be maxed out, and they are capable of a bucket load more power than 300awkw
edit: and stock injectors will get 300rwkw and be safe too. Its been done!
550cc = 550bhp
/ 1.34 = 410kw
-75 = 335rwkw
307kw @ 97%
316kw @ 100%
316kw is not too far from your calc 335kw, esp when the 550hp start figure is just a rule of thumb.
A difference of just 19kw is what you are disagreeing over, which could just be a differnce in dyno's
The ONLY way for sure to prove any of this is for SAM-r32 to flow test his injectors to know what he has
Until then, WE can all only guess.
Where do you get 19 from?
Its 28kw actually (335-307), which might as well be 30rwkw for all it matters as its 80%. For each % its nothing to get excited about, you could run at 83-84% no problem and then all of a sudden your not far off 350rwkw and your 40kw difference then.
Its not guess work at all, he doesn't have anywhere near 550cc worth of injector flow if he is maxing out at 307kw, not in his wildest dreams.
550hp is the max hp from 550cc @ 100%cc, not at 80%
Since you were quoting 335kw MAX, I calc'd 97% @ 307kw to be 316kw @ 100% MAX
335kw minus 316kw is 19kw
A simple 19kw can be in difference dyno readings.
People have run 300rwkw (more than one car) with factory injectors
People have run 330rwkw with 550's
400rwkw on 600's
http://www.skylinesaustralia.com/forums/in...st&id=10860
370rwkw on 600's (and i know these werent even near the limit as i live with the guy that helped build it)
http://www.skylinesaustralia.com/forums/in...st&id=20109
Surely these two would be dead? I mean, as the limit is 372rwkw (to be exact by the theory).
These motors should be throwing pistons!!!
300rwkw on stockers
http://www.skylinesaustralia.com/forums/in...st&id=10930
275rwkw on stockers
http://www.skylinesaustralia.com/forums/in...t&p=1854575
305rwkw on stockers
http://www.skylinesaustralia.com/forums/in...t&p=1934095
280rwkw on stockers
http://www.skylinesaustralia.com/forums/in...t&p=2903298
310rwkw on stockers
http://www.skylinesaustralia.com/forums/in...t&p=2920655
I give up. Your right.
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
