Since the discussion seems to be revolving around my rule of thumb and my experiences in drivetrain losses, I thought I might jump in here.
444 cc = 444 bhp, that includes allowing for acceleration and cold running enrichment (the 80% you commonly hear people refer to).
So you don't multiply 444 by 80%, my rule of thumb already allows for that, it's 444 cc's and 444 bhp.
Drive train losses, I have had enough engines on engine dynos and chassis dynos to know how much drive train losses to allow for. That inlcudes 2wd Skylines, 4wd Skylines, V8 Supercars, F4000's etc etc. All I can do is tell you what I have seen with my own eyes. It's been around 7 years since we had the same RB on the engine dyno and then on the chassis dyno, but it was the 4th one that year, and the results were consistent. The 2wd's lost around 55kw and the 4wd's around 75 kw. That result was very consistent from 475 bhp (on the engine dyno) to 660 bhp (on the engine dyno). Which interestingly disproved the % method of calculating drive train losses, which I never subscribed to anyway.
Some further background, that was pre Shoot Out mode Dyno Dynamics. But we have always used the same calibration methodology over the 4 DD roller dynos we have used in the 7 years and the same operator. The cars that we have had for that period of time show very consistent power outputs, so I am confident that the chasis dyno numbers are repeatable.
Moving on to the topic at hand. The 307 4wkw seems a bit high for 444 cc injectors, they tend to run out around 280 4wkw at 12 to 1 A/F ratios and 265 4wkw at the often used (so called "safe") 11.5 to 1. A 27 4wkw (7%) happy dyno is a bit unusual unless some inlet air temp or other cheating was going on. Maybe it's a 12.25 to 1 A/F ratio tune, or the fuel pressure is 41 psi instead of 38 psi, maybe a combination of all of those. Slightly happy dyno, inlet air temp creap, tiny bit up fuel pressure, slightly lean A/F ratios.
Now 550 cc injectors, I have used that size many times and with standard fuel pressure they are usually over 565 cc's. The 307 4wkw is a bit low for them, I have regularly seen 350 4wkw at standard (38 psi) fuel pressure. We usually run around 42 psi and 380 4wkw is the go then, which is a bit over 400 rwkw in 2wd.
The bottom line, my guess, if it was 307 4wkw on our dyno, would be that it has 500 cc rated injectors.
Cheers
Gary
woh... thanks guys lols..
didnt think it would get like this.. just wanted to noe if i could just simply
install new injectors.. but yea.. thanks for all ur words.. sepcially
sydneykid.. u've all been helpful.. i shall make my decision soon on wat to do
and will keep everyone posted on wat's happening with it.
thanks again
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
