Fs: New And Used Ferodo Ds3000 Pads, Titanium Shims
Beauty, thanks guys, got some ideas now. I note that none of you agreed with the flap disc so that's good to know. 馃憣馃徎
I had small pin holes in my glazing putty but didn't want to put more putty to not make a mess again and I put 2 coats of epoxy primer to prevent it from rust. Though you can only see the pin holes if your eyes are almost against the panel. Do you think when the 3x coats of high fill 2k primer and 2 base coats go on that it will be visible?
I would soak the foam with this stuff for about 10 mins then scrape off
Warm it up with a hair dryer or gently with a hot air gun.
By Murray_Calavera 路 Posted
My first thought is to use something like this https://www.bunnings.com.au/goof-off-177ml-adhesive-remover_p1580913
