What Turbos Are You Running On Your Rb25?
plus got rid of his chaser, :rofl: plus the stocko mani can take to 300rwkws but it is best to change it if you can, thats why 3040 is the way to go plus the reason he doesnt want to go high mount i think is mainly because of the lacko space in the gtt's engine bay with stock inlet manifold n shit in there, alot less room than the 33's for sure
He has heaps, he owns and R34 and an AUDI... :)
haha too much drug deals bud !
Your right noel i will be investing in some decent low mount manifolds ...If not then Custom ones are the go
As Andy said i dont want to pop the bonnet and have huge snail hanging around these days you never know what you can get yourself in to (law wise)
Ah come on Daniel what skirt you talking about its already off lol remember you peeked at it last time we met at nite :) hah
Adam .. what coilovers you get ? should have rebuild your tein ones btw have a safe trip
hi mate. just read your title, not the info posted.
if u want to go over that 300kw mark like a fair few of line owners here u will find it difficult to find a small turbo to make that power. that was my problem. so i just bought a gt3540....and got gcg in sydney to fit some titanium wheels on there. and i have never looked back. here is my setup.
BUT, if u want say 250kw.... i recommend the popular gtrs turbo. seems to go hard.
I never had teins before hand but do now, god damn no more bounce woohoo, the other ones were fooked real bad, and the name of them were G PRO Suspension the old ones, but the tiens i found arent too bad for what they are at least i dont bounce around like hydraulics on steroids now
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
