I have a Nismo Pump, Nismo Fuel Reg,Highflow and a Z32 on the way.
Wanting 250rwkw...Should I do the injectors or max out the stock ones as I have been told it will work no problem?
My Gut tells me to get em but my wallet and wife says "Use the ones you've got"
Help!!!!! Is it too much of a risk???
Dave
https://www.sau.com.au/forums/topic/206634-r33gts-t-upgrades/
def go injectors.
I upgraded to nismo 555cc injectors with my hi-flow set up. the standards were 90% duty cycle when giving it at the track.
got the 555cc's and max I have seen would be 60% with 235rwkw
Hmm thats what i thought but my tuner doesn't want me using them. Just nismo's 555 have certain issues, 740s are fine apparently. He said anything other then nismo 555's. Sards are too much stuffing around and not sure if tomei 555s are the same as nismo. I did have a reason, but forget at the moment. Will ask him again what the prob with them is....
555s have issues???? :teehee: Only the biggest and best tuning companies in the world use them not only on customers cars but their own cars.
Ive had them in my car for a year now,no complaints.
Yes i know this, that's why i'm asking the questions. Wish i could remember what he said to me lol, he explained a little problem they tended to have. Might be awkward rocking up with nismo 555s after he said not to haha. Dunno what to do?? Should i just buy em and say yeah i'm gonna run with 555s? Or go nismo 740s (i will have close to 300rwkw in the end)? :teehee:
Yer i know that but like i said, my tuner doesn't want me to run the 555s. Said i can run the 740s as they are different. Price is of no concern. Will have to call him up tommorrow and get the low down on the situation.....PM me if ya like to talk further :teehee:
  • 3 weeks later...
Getting excited now, have just sent turbo to be hiflowed... been told its getting a TO4 compressor and 56mm exhaust wheel, dunno what that means really but it sounded good....Bigger than whats in there I bet so thats a bonus.
Next are injectors then off to the dyno I go.
Dave
Edited by Turbo Dave
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
