i had a S2 turbo ran 13psi on weekends or when on spirted drives oh and 1 drift comp and turbo lasted about 3 or 4 months, then one day just on low boost low revs turbo decided it had enough, now funnily enough most problems with these turbo's is the rear ceramic wheel flying apart but in my case i blew a chunk out of the front wheel the size of a 10cent piece, so maybe the good tune can protect the rear wheel but in the end at that boost the turbo is most likely going to go, but good luck hopefully you will get a bit more life out of her
the turbo is rated according to SAU users at running no more than 12psi on an rb25
now remember that at 6000rpm on a 2.5L motor there will be more exhaust gas going through the turbine that at 6000rpm on a 2.0L motor. this means that the exhaust gas temp will be higher on the rb25 than on the rb20
this means that the same turbo on a smaller motor can easily handle 2psi or more because the same turbo at 14psi on a 2L motor is doing about the same work as 12psi on a 2.5L motor
i ran an rb25 turbo on my rb20 for about 1.5years at 14psi and the turbo ran happily all day every day with me driving it like i stole it!
Edited by WazR32GTSt
I had mine running 11psi... Was driving down hill and let off the accelerator and BOOM!!!!! both wheels disintergrated! run 10 pound if u must but no more...
Just putting it out there.i did see my turbo hit 24psi when first installed it and its still in good form.
they can take it,but for how long and is it any benefit over the usual 12psi.
I dont know if u've found ur problem yet or not but it could possibly be either a gasket leak between the manifold and turbo or u may possibly have snapped 1 or more of the 4 studs that hold the turbo onto the manifold... I had my RB20 doing the same and a mate found out that one of the studs was missing and a tiny bit of gas was leaking from there making a little high pitched whizzing noise..
Just to note i ran an RB20 turbo actuator (10psi) all day on my 33 turbo and with the 3 inch exhaust gained 1 or 2 psi on top of that depending on the conditions. I always thought the turbo was stuffed but it was just a tiny leak.
Liam
Edited by FordyR31
did you change the gasket when you did the turbo?
i have an rb25 turbo on my rb20 and i have no odd noises but i changed the gasket, i have a friend who didn't and he has a similar noise to what you say
thanks for the heads up guys...im going to get a malpassi rising rate fuel pressure reg or a nismo one and ive got a apexi n front mount, exhaust, ebc so im hoping to tune up the safc next weekend and bring the boost up to 14psi....hopefully see the 190rwkw mark.
Correct me if I'm wrong but i'm pretty sure that the rb25 series 2 R33 have a nylon compressor wheel, which may cause it to sound a little different to when a steel wheel is spinning up? if this is the turbo you're using it may be the reason, when I changed
mine over from standard to hks 2530 totally diff noise when spinning up.
Just a thought.
15 psi for 40 000km is all i have to say :) noticeabley runs about 10-15 degrees hotter but thats not the end of the world. Nethign over 15psi seems to hit boost cut but just on 15psi seems fine day in day out lol for a daily R33.
Turbo still going strong but has since been set to 10psi for fuel consumption savings lol plus doesnt liek 15psi and stock smic oh hot days on cold days though 15psi all day.
At the end of the day the turbos are cheap and everyone would rather upgrade their stock turbo eventually neways.
Edited by SPINR33GTS
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
