Hey its me again !
I've heard a lot of exhaust problems and all
but i've heard people putting on a silencer and increase power...
I would like to know if anyone here who can quote me a price on a silencer
and where to get them?
Overall, any information on silencers (like if its a universal adaptor) would be great
david
https://www.sau.com.au/forums/topic/206658-silencer/
silencer doesn't increase power.
to put it simply, it'll make an overly large diameter exhaust smaller, i.e. 3" and by doing so increases the volumetric vacuum efficiency of said large exhaust.
most exhausts have to be designed with a silencer.
as for quotes, search the regular online performance shops or head down/call your local exhaust shop.
simple.
/thread to be closed.
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3655215
any place that sells mufflers should have them
they are just a piece of pipe with a sort of round dish that bolt straight into the tip of your cannon muffler
you could get the same effect by getting a flat bit of metal the same size as your muffler tip and drilling a hole in the middle of it. then stuff that into you exhaust..
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3655524
wouldnt worry about a silencer....
get an Oval style resonator put in....
will make it quieter, and give it a gruntier sound....
i originally had a 4inch canon put on a 2.25inch exhaust...was running crap
put the silencer on, ran better...
took the silencer off and added an oval resonator, runs better
next, reducing cannon size, keeping piping and resonator...run best..... :)
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3662516
Cuz you got an N/A car, if you put a 3" exahaust / large cannon muffler, you are loosing back pressure volumetric efficiency. By placing the Silencer in, it narrows the In-pipe of your cannon muffler and reduces the size back down to say 2.5" so your not loosing back pressure volumetric efficiency. = Get you power back up.
Silencers, pretty much a metal cylender, goto any exhaust place and they can make / measure one up for you. Or if you bought an aftermarket exhaust, they usualy come with a silencer.
Edited by Eug
correct terminology
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3669290
i have made the appropriate edits in the above post...
it's funny seeing people who know about something without even knowing the correct terminology or even how to spell. hardly makes the information provided seem credible and will only confuse others from my personal point of view.
while this isn't a direct attack on (00)SKYLINE(00) i am merely using him/her as an example to inform others of the correct wording for future reference, more accurate search results and to prevent confusion with new forum members.
cheers
eug
p.s. - the thread will remain open, but the ideology that a silencer will increase power is not entirely correct. in the instance of an excessively large exhaust you will regain the response lost by installing a silencer into said excessively large exhaust. however on a well suited exhaust with efficient volumetric vacuum/scavenging characteristics (2.0" ~ 2.5") installing a silencer will more than likely create back pressure, and thus decreasing the efficiency of the exhaust.
just remember, back pressure is bad - you do not want it. increasing the volumetric efficiency of an exhaust will decrease back pressure.
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3669388
Just want to make sure, but if you have a set inlet size (say 2.5") the muffler tip size only affects the noise that comes out of your car and has nothing to do with performance or any other factor, correct?
This is of course assuming the the muffler tip is at least 2.5" too.
Thanks.
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3670512
Hi guys, i had a silencer on my 6" cannon with a 4" tip
I use it for the longer trips at higher speeds to keen the fiance from getting a headache!!!
Ive stopped using it now though because it left a whole lot of black exhaust crap around the exhaust edge and silencer.
It looks good though, but id only ever use it as a show accesory, not much else.
You can kinda see the silencer in this pic
http://s21.photobucket.com/albums/b258/EMZ...nt=IMG_2706.jpg
And compaired to without
http://s21.photobucket.com/albums/b258/EMZ...nt=IMG_2523.jpg
EMZ
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3694910
Damn, as you know I put 2.5" system recently,,,but it wasnt with a oval resonator.........its with a donut resonator, so when i run without a silencer it was sooooo loud, So i put the silencer back in so it runs smooth.........
So if i put a oval resonator instead of a hotdog one, i wont need to put a silnecer and create any back pressure ya?
Just thinking, do I have to get rid of the donut one to replace oval one or can I just add oval one with hotdog one (keep both)?
Cheers
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3703245
that was way too confusing... oval donut oval donut oval donut.
to be honest, just do what you think feels right. there is no perfect setup, not unless you want to invest the time and money on bench flow tests and buying different exhausts. it's alot of R&D involved.
the 2.25" - 2.50" is a general rule of thumb!
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3703570
hehehe :woot: my bad.......just thought that using a oval resonator will reduce noise better than hotdog resonator, thats all.
Cheers :D
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3706648
Got a question regarding this.
I know that if you put a 3" exhaust system on a N/A car it will lose power as it doesn't have enough volumetric efficiency.
I'm getting a cannon put onto my car this Friday, nfi what size it is, I'll post a pic up to help. But anyway, the pipe from the flange back towards the cannon is the same as stock size and the cannon increases in size a fair bit. Will I lose power from this?
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3714684
I have a silencer in mine. With the silencer out, there is a huge increase in noise, and a slightly noticable gain in power. I keep the silencer in for the road, but take it out for skid pan days etc. Car sounds way more angry and aggressive with the silencer out. :(
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3724616
Yes i pulled mine perm out but in the back of the car..... so if i do get pulled over b4 i get a yellow i can knock it back in and bult it in and start it up and the police should be kewl with it.
Even so ur car can go up to nine decibel in sound and with it out i do not think it hits this and just drive like a sane person if u floor it police will grab u on the flooring and will not worry about the sound.
HaPpY Driving people
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3754608
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
