Hey its me again !
I've heard a lot of exhaust problems and all
but i've heard people putting on a silencer and increase power...
I would like to know if anyone here who can quote me a price on a silencer
and where to get them?
Overall, any information on silencers (like if its a universal adaptor) would be great
david
https://www.sau.com.au/forums/topic/206658-silencer/
silencer doesn't increase power.
to put it simply, it'll make an overly large diameter exhaust smaller, i.e. 3" and by doing so increases the volumetric vacuum efficiency of said large exhaust.
most exhausts have to be designed with a silencer.
as for quotes, search the regular online performance shops or head down/call your local exhaust shop.
simple.
/thread to be closed.
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3655215
any place that sells mufflers should have them
they are just a piece of pipe with a sort of round dish that bolt straight into the tip of your cannon muffler
you could get the same effect by getting a flat bit of metal the same size as your muffler tip and drilling a hole in the middle of it. then stuff that into you exhaust..
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3655524
wouldnt worry about a silencer....
get an Oval style resonator put in....
will make it quieter, and give it a gruntier sound....
i originally had a 4inch canon put on a 2.25inch exhaust...was running crap
put the silencer on, ran better...
took the silencer off and added an oval resonator, runs better
next, reducing cannon size, keeping piping and resonator...run best..... :)
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3662516
Cuz you got an N/A car, if you put a 3" exahaust / large cannon muffler, you are loosing back pressure volumetric efficiency. By placing the Silencer in, it narrows the In-pipe of your cannon muffler and reduces the size back down to say 2.5" so your not loosing back pressure volumetric efficiency. = Get you power back up.
Silencers, pretty much a metal cylender, goto any exhaust place and they can make / measure one up for you. Or if you bought an aftermarket exhaust, they usualy come with a silencer.
Edited by Eug
correct terminology
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3669290
i have made the appropriate edits in the above post...
it's funny seeing people who know about something without even knowing the correct terminology or even how to spell. hardly makes the information provided seem credible and will only confuse others from my personal point of view.
while this isn't a direct attack on (00)SKYLINE(00) i am merely using him/her as an example to inform others of the correct wording for future reference, more accurate search results and to prevent confusion with new forum members.
cheers
eug
p.s. - the thread will remain open, but the ideology that a silencer will increase power is not entirely correct. in the instance of an excessively large exhaust you will regain the response lost by installing a silencer into said excessively large exhaust. however on a well suited exhaust with efficient volumetric vacuum/scavenging characteristics (2.0" ~ 2.5") installing a silencer will more than likely create back pressure, and thus decreasing the efficiency of the exhaust.
just remember, back pressure is bad - you do not want it. increasing the volumetric efficiency of an exhaust will decrease back pressure.
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3669388
Just want to make sure, but if you have a set inlet size (say 2.5") the muffler tip size only affects the noise that comes out of your car and has nothing to do with performance or any other factor, correct?
This is of course assuming the the muffler tip is at least 2.5" too.
Thanks.
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3670512
Hi guys, i had a silencer on my 6" cannon with a 4" tip
I use it for the longer trips at higher speeds to keen the fiance from getting a headache!!!
Ive stopped using it now though because it left a whole lot of black exhaust crap around the exhaust edge and silencer.
It looks good though, but id only ever use it as a show accesory, not much else.
You can kinda see the silencer in this pic
http://s21.photobucket.com/albums/b258/EMZ...nt=IMG_2706.jpg
And compaired to without
http://s21.photobucket.com/albums/b258/EMZ...nt=IMG_2523.jpg
EMZ
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3694910
Damn, as you know I put 2.5" system recently,,,but it wasnt with a oval resonator.........its with a donut resonator, so when i run without a silencer it was sooooo loud, So i put the silencer back in so it runs smooth.........
So if i put a oval resonator instead of a hotdog one, i wont need to put a silnecer and create any back pressure ya?
Just thinking, do I have to get rid of the donut one to replace oval one or can I just add oval one with hotdog one (keep both)?
Cheers
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3703245
that was way too confusing... oval donut oval donut oval donut.
to be honest, just do what you think feels right. there is no perfect setup, not unless you want to invest the time and money on bench flow tests and buying different exhausts. it's alot of R&D involved.
the 2.25" - 2.50" is a general rule of thumb!
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3703570
hehehe :woot: my bad.......just thought that using a oval resonator will reduce noise better than hotdog resonator, thats all.
Cheers :D
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3706648
Got a question regarding this.
I know that if you put a 3" exhaust system on a N/A car it will lose power as it doesn't have enough volumetric efficiency.
I'm getting a cannon put onto my car this Friday, nfi what size it is, I'll post a pic up to help. But anyway, the pipe from the flange back towards the cannon is the same as stock size and the cannon increases in size a fair bit. Will I lose power from this?
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3714684
I have a silencer in mine. With the silencer out, there is a huge increase in noise, and a slightly noticable gain in power. I keep the silencer in for the road, but take it out for skid pan days etc. Car sounds way more angry and aggressive with the silencer out. :(
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3724616
Yes i pulled mine perm out but in the back of the car..... so if i do get pulled over b4 i get a yellow i can knock it back in and bult it in and start it up and the police should be kewl with it.
Even so ur car can go up to nine decibel in sound and with it out i do not think it hits this and just drive like a sane person if u floor it police will grab u on the flooring and will not worry about the sound.
HaPpY Driving people
https://www.sau.com.au/forums/topic/206658-silencer/#findComment-3754608
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
