adam 32 Posted August 18, 2002 Share Posted August 18, 2002 166kmh Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49039 Share on other sites More sharing options...
Guest KILLER-T Posted August 18, 2002 Share Posted August 18, 2002 166 kmh will get you into the 13's easy so there you go your car is not a piece of **** Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49041 Share on other sites More sharing options...
adam 32 Posted August 18, 2002 Share Posted August 18, 2002 but running 8psi!!! its not enough power:D i wonah boost it to 12psi and get a new fuel pump, then well try again! Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49043 Share on other sites More sharing options...
rob77 Posted August 18, 2002 Share Posted August 18, 2002 Well I didnt have much luck. With the warmer weather and the stock intercooler I couldnt run 0.8bar of boost effectively. My fastest run of the day netted me the same result from my last day at the drags another 14.8 with the boost turned down to 0.6bar. Time to browse the Trust catalogue for a better intercooler and some sort of new engine management I think. The car was launching much better with the lock kit though, its a bit annoying though as I know the car is quicker because at night when its much colder at 0.8bar the car pulls strongly to 6500rpm, today with 0.8bar I had to keep shifting between 5500 and 6000rpm because the power was tailing off... damn heat! Either that or my car's a lemon Rob Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49051 Share on other sites More sharing options...
skyzerr33 Posted August 18, 2002 Share Posted August 18, 2002 rob77 was yours the black R33 with stock rims? Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49062 Share on other sites More sharing options...
Gradenko Posted August 18, 2002 Share Posted August 18, 2002 Originally posted by MrSnrub Also what dyno did you get 253rwhp on? I know what you're thinking, and no, its not Myaree Dyno Got it tuned at Barrys Dyno. adam 32, no need to prove anything, the terminal speed shows the true potential of the car. Besides, 12psi will make you harder to catch at the next cruise rob77, the factory tune on the r33 ecu is junk. Put fuel control at the top of your list, you won't be sorry. Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49063 Share on other sites More sharing options...
skyzerr33 Posted August 18, 2002 Share Posted August 18, 2002 Rhino did well with nearly braking into the 12's and that nitro vs ss ute was kewl to watch all over the road. i think big adam needs to turn the boost up more than 15psi i got 30 odd pics dump pipe and night runs and i'm there next time Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49064 Share on other sites More sharing options...
rob77 Posted August 18, 2002 Share Posted August 18, 2002 Yup, black r33 stock rims and body, nice 3.25" cat back system with the muffler on a angle and a tip big enough to stick your head in The only other mods are a blitz air filter element, apexi twin chamber bov (which I'm thinking of ditching cos I think its causing my problems), blitz dual sbc type s boost controller. I was hoping on at least a low 14, possibly a high 13, but the gremlins re-appeared. My terminal speed was 96.05mph or 154.57kmh at 0.6bar, so with a stronger clutch and harder launch, I dont see why I cant run a low 14 at least. Rob Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49075 Share on other sites More sharing options...
adam 32 Posted August 18, 2002 Share Posted August 18, 2002 0.6bar = 8psi you should be able to run 10psi through the std intercooler no worries Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49081 Share on other sites More sharing options...
gtrken Posted August 18, 2002 Share Posted August 18, 2002 OK, what's the quickest WA 1/4 mile time for a Skyline of any type?? Has need4speed or Techone run a 1/4 mile time yet. Ken Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49082 Share on other sites More sharing options...
rob77 Posted August 18, 2002 Share Posted August 18, 2002 Adam32 read my post, I run 0.8bar of boost and it's fine at night, the car pulls hard all the way to the 7200rpm limiter, but for some reason today be it heatsoak or something else is ****ed in the car, it was loosing power if I went past 5500rpm. I'm sure if I went out now and took it for a drive, it'd pull fine to 7200rpm. *shrug* beats me, everytime I go to the drags something ****s up. Rob Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49087 Share on other sites More sharing options...
adam 32 Posted August 18, 2002 Share Posted August 18, 2002 yeh i understand that happens at 0.8bar which is around 12psi but why not find some middle ground ie 10psi cos at that boost the car would have run fine and you could have run a better time.... maybe just have to wait for wednesday nights to come back! Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49089 Share on other sites More sharing options...
rob77 Posted August 18, 2002 Share Posted August 18, 2002 Yeah, well I didnt tune the boost controller. Anyway, a larger front mount cooler will fix the problem and a new ecu wont hurt either. Rob Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49090 Share on other sites More sharing options...
Gradenko Posted August 18, 2002 Share Posted August 18, 2002 Originally posted by rob77 [snip] The only other mods are a blitz air filter element, ... [snip] So I take it the blitz element is in a stock unmodified airbox? Or have you hacked the airbox to include a cold air intake? The stock airbox is an unbelievably huge restriction in R33 GTS25ts, the GTR design is much better. Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49100 Share on other sites More sharing options...
Pva_Glue Posted August 18, 2002 Share Posted August 18, 2002 damm I think I missed out on the Fun day of the year!!!... sorry guys I could not be there... I would love to see all of you again and the cars... I was pre occupied with something else... sorry... SMS troy but it was too late... see you on our next cruise... cheers Joe Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49103 Share on other sites More sharing options...
Guest Rhino Posted August 18, 2002 Share Posted August 18, 2002 Only did 6 runs as I was stupidly consistant, here they are in order: 13.989 @ 167.24 13.112 @ 163.47 13.038 @ 168.41 13.080 @ 164.95 13.073 @ 161.64 13.093 @ 168.41 As Troy said today there was a bee's dick to a 12 for me today, I wont be going back until I get a new clutch and make sure I dont have 50L of fuel onboard like I did today...........and maybe flogg some race rubber off Ken??? pretty please?? Cheers. Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49105 Share on other sites More sharing options...
Guest Rhino Posted August 18, 2002 Share Posted August 18, 2002 Ohh yeah lets get them photos coming too And I think one of Mackas mates took some video footage? I'd really like to have a closer look at my runs from 'outside' the car. Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49120 Share on other sites More sharing options...
JH32 Posted August 19, 2002 Share Posted August 19, 2002 Well done guys that was a top day ... I even got a little bit sun burnt sitting up there in the stadium! Lots of good times and lots of nice cars :uh-huh: Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49193 Share on other sites More sharing options...
ix9 Posted August 19, 2002 Share Posted August 19, 2002 Ben: Yeah man, i think you were too busy liftin the bonnet of your beast in the pit lanes to realise i was runnin around... I was wearing the dark blue polo shirt with www.hyperwa.com on the back.. Also guys, there's an image gallery up at http://hyperwa.com/gallery/dragwars02_s9/ so you guys can see your ride's.... Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49195 Share on other sites More sharing options...
IMACUL8 Posted August 19, 2002 Share Posted August 19, 2002 Great pictures .... you must have one sweet camera.... Well done.. Dan Link to comment https://www.sau.com.au/forums/topic/2067-motorplex-meet/page/9/#findComment-49198 Share on other sites More sharing options...
