  • Replies 159
People, check with your insurers first. I was going to get these for my MR2 but Just Car said they dont cover scissor doors or carbon bonnets for that matter.
I do like them but just didnt get them because of this reason. Id say youd have worse luck with the likes of NRMA or AAMI covering these aswell.
Also make sure your passanger is fully aware of the scissor doors as the brackets can bend if pulled open too far, ive been there before, LOL
Just because they do not cover it doesnt mean you cant have it on the car..
I called them and asked about a CF bonnet as my GTR bonnet was damaged in a hail storm. They told me I was allowed to put in on the car and there wont be any problems but if I am in an accident or some thing happens to the bonnet they will replace it with a standard bonnet.
So when they say "they dont cover it", they usually mean they will replace with standard if a claim is made.
Yeah im definately interested thats why i started this thread up, good to see more people are interested as i just hear rice rice rice when i talk about it, need to save up some cash though, but if the cops do see us opening the full doors and we dont see them and get defected, we would have to put the standard doors back on which is gonna be a bitch to do because installation isnt so easy.. got any pictures of these bespoke Carbon fibre parts?
Some kits out there claim to be fully reversable. However they dont mention how easy/hard it is the reverse it.
  • 2 months later...
These are hot off the production line as we speak. R33 GTST Series 2 Carbon Gear surrounds. Ignore the yellow bits around the Cigarette lighter aperture. That is residue polish. More interior parts to follow.
ohh sexy!!! i want these
Hey mate, any prices on these? And is the rest of the interior available? I'm interested.
Easy find on his website :unsure:
$197 AUD + Shipping
http://www.lambodoorkits.co.uk/carbon-desi...und-p-5744.html
Any plans for any R32 parts Terry?
We have plans to do the whole interior for R32, R33, R34 and the New GTR when we get our hands on one. All models will be catered for included GTST, GTR and GTT.
If you do the whole interior and sits flush like the stock parts then im in for sure.
They are a direct copy of the original, as we send off the parts to the factory and take a mould from it. The gear surround as you see above is made from a fiberglass shell and then covered with genuine grade A carbon fibre. Then fade resistant laquer applied.
Any timeframe on when the whole interior for R32 Gts-t will be ready? Im not very patient lol
Hoping within the next couple of months, depends on interest really. Only had 15 views on ebay for the R33 GTST/GTR gear surrounds which is pretty poor.
  • 3 weeks later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
