well i have decided that i want gtr injectors in my rb25! because my injectors is side fed and gtr is top fed, i just wanna know how i can go by putting them in!
would i have to modify my rail and how would i have to do it?
if there's anyone who has done it or have ideas on how to i would greatly appreciate it! or if anyone has a set of 6 s15 injectors i would gladly buy them off you!
cheers
https://www.sau.com.au/forums/topic/206763-gtr-injectors-in-rb25det/
slidewize imports get some from japan
http://www.slidewizeimports.com/
since we cant get stuff from yahoo direct slidewize bids for us gets shipped to his Japan address and then on to us
>>Yahoo Injector Page<<
just calculated 400HP which is roughly 300Kw
so if you got 550cc you've got a little headroom for more power
Power: 400 horespower
Number of injectors: 6
BSFC: 0.65
Duty cycle: 0.85
This combination will require 535 cc/min injector (51.0 lbs/hour)
cheers guys! but i've decided to go for 200kw atw first so sticking to standard injectors would do the job! but in a few months time i will be getting my engine rebuilt! forgies, cams and maybe bore it to the max (2.6 litre) and a different turbo! but it's decided to go for 200 first =)
770 is a bit of overkill i think you only roughly need 450cc for 300kw
i am always thinking of room for expansion lol.....nothing wrong with 770cc injectors....
engine rebuilt and your only boring out a RB25 to a 2.6....correct me if i am wrong but i thought with RB25's you could bore it out to a bigger capacity to more like 2.8 or something....if i am correct why not do the 2.8 instead of the 2.6
yeah ^^ coz i think my mate had his RB20 bored out to something like a 2.3 or a 2.4l.....and i have also heard of RB26's being bored to 2.9-3.0l....so there is no reason in my mind as to why a RB25 cannot go to 2.8 or so...but i guess nos_man you will have to do a bit more research on that....ask you mechanics and see what they say or recommend....
2.7 is the most common set up for the 25 i believe running gtr crank n rods to do this...
anyone know if 25 injectors will fit in the 26 rail?
The 25 uses high impedance side feed injector where as the 26 uses low impedance top feeds. i know where you can get a top feed fuel rail made up for a 25 though.
Edited by D_stirls
yer kool its just im looking at running a 26 plenum and throttle set up on a 25, so wasnt going to change to 26 inj because of the impedance :)
you can always use resistors! but i reckon it's not worth it! better off getting something like rx7(13b's are 550cc), s15 injectors if you're on a budget like i am! but i thought i would give it a shot but nah........
Edited by nos man
I ordered Deatschwerks 450cc injectors, was pretty cheap. Was going to get the 480cc items, cheaper than S15 ones, and they suggested to get their 480's but then said only stock was 550's...... so they gave me 550cc injectors for the 450cc price. pretty decent deal. Plus factor is that Deatschwerks are world renowned for their quality hi-flows.
If you are after some $$$-saving, contact them in the States and see what they can do for you.
lol;
Once again;
So no they won't fit.
If you don't want to stuff around with resistor pack and such use injectors suitable for RB20's because they will be top feed so they will fit the RB26 rail and the will also be high impedance so you won't have to change anything in the wiring.
New Injectors- Perfect Run.com
Have a look at the link above, a set of Sard 650 or 800cc's (both the same price) will cost you ~ $610 delivered.
Edited by D_stirls
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
