im seriously considering going an RB30det.... i need someone on her to tell me its a good idea to go and blow some money on doing it.
Basically ive got an RB25det atm with a GT3071R making 265 rwkw on 16 psi or 1.1-1.2 bar ive got cams coming to improve the lowdown (i dont run VCT atm) and the car is used for drift which isnt all about peak power.
I am getting my hands on a spare 25det head and RB30 block. My plans for the block were to put ACL rings, brearings and so forth in it, freshen it up, 25det oil pump with the crank mod to give more drive area. once this was done i was going to put the 25 head on it with a stock nissan HG and my 254 8.9mm lift cams the aim of the game is to keep it simple and reliable... I do not plan on making much more peak power then i am now (FWIW i made 282 rwkw on my 3071r on 20 psi) but what i do want is a HUGE midrange and instant responce.
am i on the right track or should i just stick to the 25?
Im a mechanic, so will be getting parts on the cheap and building the bottom end myself. the cost all up for the upgrade is budgeted at around $1000. Thats 2-300 for the crank mod (would get someone to do that for me) then 500 for ACL race bearings, ACL rings, gasket kit, front and rear mains seals, and head studs.
discuss.
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/
  • Replies 72
What pistons do you plan to run, and what static compression ratio?
Also what sort of rpm ceiling?
I may be slightly wide of the mark, but it seems that mild 30DET builds often produce similar maximum power figures to the donor 25DET, but at lower rpm. Their advantage is in torque, and with your spec 3071, I would say rapid response. Bigger torque would turn tyres easier, but is there any problem if you run out of revs?
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3657896
7500 is the current RPM limit... i would prob drop this back to 7000 for a 30DET in the aim of reliability. the fact that the 30det will make more torque earlier, and hopefully for longer means that if i do start to run out of revs all i need to do is shift up a gear.
As for pistons... i plan on stockers... unless someone suggests other wise... basically im just after a mild package. i really dont see myself going for a 400 rwkw package, All i want is to make the same peak power or maybe 10-20 rwkw more. but with a shitload more responce and torque throughout the revrange.
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3657954
i think joels is a larger turbo then mine.. but thats a moot point really.
one other thing, should i use a 25 or 26 oil pump?
Also, with the 25 head, i dont plan on running the VCT at all so its operation isnt needed, Do i still need to weld up the feed for it? or is there a way around it? If welding it up is the only way what is the correct way to go about it?
Edited by Simon-R32
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3658376
drill it out - tap it and usea grub screw - that way if ever you go back to rb25 or sell off the head it can still be used.
also no need to redeck the head - unless your doing that already
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3658498
run into issues with vct and these engine builds dont you?? something about where the added tensioner goes? or a oil gallery? il have to check again, but everyone says "dont use vct"... id also like a deffinate answer if anyone knows?? :P
CJ
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3658554
im also thinking a 3L bottem end if mine decides to shit bricks. But on the other hand thinking of prepping a 26 crank, getting steel rods, and boring my engine out to a 2.7ltr with a 9,000rpm limiter :P 25psi on the 3540 and hks cams.
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3658583
Do it
Use a decent oil pump though if you plan on smacking the limiter a lot - get a JUN one :P
If you dont like it, refit the old RB25 with fresh rings (and whatever else)
Read the RB30 results thread, there are some big numbers in there for even stock 3L bottom ends
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3658706
thanks guys, yeah i have read through the RB30 thread, theres some 400 very informative pages but it makes finding what you want to know very hard lol. very impressive power figures being made too.
the grub screw idea sounds great, easy as pie too.
i dont want to run VCT since i have an RB20ecu remapped to run the 25 atm, no VCT control... besides ive got some cams coming anyway so i dont really need the VCT. if its less hassle i def wont bother rigging it up.
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3658804
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
