SK, your point about the power steering bracket. I had to modify mine to get it to fit, it's simply that the thing used to bolt to the head and the top boss was longer than the lower two that bolt to the block. With the 30, all 3 points bolt to the block and the top boss has to be cut back flush with the lower two.. 5min job with the whizzer disc. (This was 20 stuff.. haven't seen a 25 bracket recently so it may well be different).
My car is also registered with the RB30 here in WA. If you take it over the pits all stock looking (mine looks pretty damn stock at the moment) and with a small turbo, it is more likely to pass. Take it over with a high mount etc and you're asking for trouble :) I figured, baby steps :(
Edit: I tried to do some text drafting to get the point across but the text didn't want to line up properly :D
Edited by bubba
  • Replies 72
If you had built an RB25 or RB26 forged bottom end it would have cost more
You would have had to spend that money regardless of whether you used an RB25 or RB30 bottom end
They are directly related to power outputnot whether you chose an RB25 or RB30 bottom end to makwe that target.
So you can spend the same or more on another? You've got the bug and it's hard to shake, trust me I know.
Cheers
Gary
I was just giving an example of what money i have spent to support the RB30. power does not come cheap.
I would sell and never buy another fast car again. Buy a house instead
And you think a car is expensive :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
Wait for the water rates, land tax, council rates, stamp duty, legal fees, removalist costs, furniture, fittings, faulty plumbing (you think mechanics charge, wait till a plumber gets hold of your wallet), leaking roof, painting..............the list is endless.
Cheers
Gary
Cheers
Gary
apart from the plumber and leak issues, all the rest I've dealt with and yes..
very expensive to own your own house..
go interest rates go!!!
The council gave me a valentines day present...
Bill for $509 for this quarters rates.
I do more mods to the house than the car these days.
mulch this
mow that
plant this
paint that
purchase this
instal that
clean this
pay that
f**kers at Bunnings know me by first name.. :D
Cheers
Gary
that may be tru but at least wen u sell the house u got 60k back in the pocket....
**price may very on houses**
meh you can sleep in a car, but you can't drive a house.
The Rainbow Sheikh begs to differ he built a replica 1950's Dodge power wagon, everything on it 64 times LARGER than the original. Inside the body there is a house and it is capable of 30km/h.
  • 2 years later...
holy thread revival!!
yeah i kinda got put off the RB30 path... not because it dosnt work, cause it clearly does, but mainly because of packaging and weight dist reasons.
running an RB25 neo motor that i picked up cheap.. stock internals and making very decent power reliably. pretty happy with it as it has all the power and torque i need and loves to rev. im now focusing on putting it all to the ground properly.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
