hi i ve just put the standard air box on my gtr for a roady , wondering are these really all that restrictive ? what sort of power can these handle ,?
ive got N1s 2.5 inch dumps , 2.5inch front. and 3 inch cat back , also a 600x300x120mm cooler .?
will the air box hold it back when i take it to get tuned?
cheers pete
https://www.sau.com.au/forums/topic/206812-r32-gtr-airbox/
Do a search, been covered be4 with results. I even experimented on mine (cat back xhaust & 14psi), & couldnt believe the difference. basically scrap the bottom 1/2 to d/c it from the resonator setup & leave the top half in place. I have a k&n filter in mine. I had blitz pods on be4 but the filtration aint that great
https://www.sau.com.au/forums/topic/206812-r32-gtr-airbox/#findComment-3658458
The 32 airbox isnt 'the best', but its not 'too bad'...
The R33 one however people have had excellent results with so if you wanted to go the airbox route (and, no reason no too), chase the R33 one down
Also depends how much power/airflow your after dude, you havent provided a lot of detail
https://www.sau.com.au/forums/topic/206812-r32-gtr-airbox/#findComment-3658953
Might be worth just removing the snorkel - mine had a plastic sleeve that sits inside the internal and external pieces, that was closed in on itself and would have been restricting flow. You get at tiny bit more BOV noise but that's it.
https://www.sau.com.au/forums/topic/206812-r32-gtr-airbox/#findComment-3664296
Pete you're in a great position do all of us R32 GTR owners a favour. Try my test ie pods, stock box with a stock ie nissan panel filter, and then remove the bottom of the stock box and tape the panel in. Or even just stock box with / without the bottom half if you're not going to try pods. Shouldn't cost you anything for one or two more power runs if you're tuning anyway.
That will confirm if your experience is the same as mine and Mike's ie the bottom of the box is restrictive beyond a certain point. Remember if you're worried about legality it's also a good test as the box looks stock with the bottom half removed as the top butts up to the washer bottle, but once you put pods on it's a different story.
Cheers
Edited by Scooby
https://www.sau.com.au/forums/topic/206812-r32-gtr-airbox/#findComment-3664579
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
