I am going to speak to my mechanic about this tomorrow, but thought I would ask you guys about it too.
I'm considering buying a water cooled turbo (Garrett), but I was wondering if I would have any hassles installing it onto an RB25 engine. Does anyone know of the extra parts and labour costs I would be up for?
Also, since they are sleeve bearing turbos, does that mean it needs the water cooling to last as long as a ball bearing, or that it will end up lasting longer than a ball bearing that isn't water cooled?
Lastly, can someone please translate this for me? I don't understand the numbers at all, I just need to know if it's suitable for an RB25 and at roughly what revs it makes full boost.
Compressor: 0.6AR POLISHED compressor housing with rare bolt type discharge flange. "S" trim wheel, 1.904" (48.4mm) inducer, 2.75" (69.9mm) major.
Turbine: 0.84AR-split pulse-T3 style turbine housing with custom 6 stud (8 x 1.25 metric) discharge flange, grit blasted and painted in high temperature paint. "O" trim wheel, 2.922" (74.2 mm) major, 2.296" (58.3 mm) exducer.
If someone can give me a brief explanation of what the AR and trim etc means, I would also appreciate that.
https://www.sau.com.au/forums/topic/20682-water-cooled-turbos/
Well your compressor is a TO4 "S" flow, according to the wheel dimensions, and the 0.6a/r cover is pretty standard with that wheel.
According to my flow-map rated flow is about 35Lbs/min airflow, or 457cfm, or 305BHP, or 227Kw, depending on how you want to rate it.
Your exhaust turbine is also TO4 "O"flow split pulse 0.84a/r, as the guy says, but it apparently has a T3 flange fitted which is pretty unusual.
That sized turbo would be about right for a three or four litre sized engine I would think, but it will need an external wastegate.
As for the watercooler part... all stock R32/33/34 turbos are water cooler anyway. Just a matter of getting custom lines that will reach the outlet points on teh block for the water lines and the same for the poil line aswell. Nothing ya wouldn't have to do for any turbo upgrade other than a high-flowed stock one.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
