Date for skid and drift?
16 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey guys/guys,
I am dying for another skidpan day. So This is to see if anyone wants to do another one?
I am thinking April 5 or April 6,
Please only vote if your interested.
We would be doing it through 5th gear and as most of you know its a great day.
We would be aiming for around 10 people and i would love some supra's to attend. (so if you guys are interested post up in here).
So who is in?
1. BNR32t - 32 GTR or mustang or maybe 300zx :ermm:
2. R3sp3ct - S2 R33 (maybe)
3. Turismo - saab 900 turbo aero
4. ZCR - R32 GTST
5. DriftGTS - R31 Sillo or R31 GTS
6. CeJay - R32 4dr GTS4
7. Frink - R33 GTS-t
8. sl33py - R33 GTST
9. LadyBytes R32 GTST
10.
Edit: I will see what i can do about getting some more openings, Maybe a full day on the pad :D
New thread...
http://www.skylinesaustralia.com/forums/Sk...ar-t207565.html
Edited by BNR32t
https://www.sau.com.au/forums/topic/206826-skidpan-day/
  • Replies 73
I did this once and it was great fun, just never got my old car back to as clean as it was. Im a maybe and voted sat.
3.
4.
5.
6.
7.
8.
9.
10.
Edited by R3sp3ct
https://www.sau.com.au/forums/topic/206826-skidpan-day/#findComment-3658551
Hey guys, james here (finaly signed up) im always up for a slide!
4. ZCR - R32 GTST
6.
7.
8.
9.
10.
https://www.sau.com.au/forums/topic/206826-skidpan-day/#findComment-3659204
4. ZCR - R32 GTST
7.
8.
9.
10.
Count me in for now, my work situation is a bit up in the air at the moment, so I may cancel, but will tell you guys when I find out more.
https://www.sau.com.au/forums/topic/206826-skidpan-day/#findComment-3659399
hell yes! new diff....
4. ZCR - R32 GTST
8.
9.
10.
https://www.sau.com.au/forums/topic/206826-skidpan-day/#findComment-3660216
x2 Yes - New turbo!
4. ZCR - R32 GTST
9.
10.
https://www.sau.com.au/forums/topic/206826-skidpan-day/#findComment-3660428
4. ZCR - R32 GTST
10.
https://www.sau.com.au/forums/topic/206826-skidpan-day/#findComment-3661896
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
