  • Replies 43
Posted Images
  • 4 weeks later...
Hey lad's a couple of tips for you the best angle to use is 14-15 degree's and to get a pulse firing order you do this by matching your firing order to the collector one next to the other around in a circle, and try to get the same lengths on each pipe it's hard but you will be rewarded with more ponie's. If your useing stainless use 321 grade as this is the best grade for withstanding the heat and it weld's up a treat good luck!!
Edited by The BOP
It's to get more pressure if you have a random order they while affect the flow. It's kind of like a whirlpool and accelerates the gases out, hard to explain but that how we build all our collectors on our cars at work unless it's a tri y or cross over system but that another story again!
I ran into a mate last night that was telling me about jacketed pipes too so you can pump water around your pipes to keep temp down know thats some trick shit but dam costly and hard to make he tells me they run it on there race boats but i dont see any reason not to try it on cars. Only down side would be the extra weight but you could drop the pipes wall thickness down to compensate, just a few more things to think about
never heard of making the firing order go round in a circle but sounds quite interesting.... any physics behind this you can explain?
most boats run water around the exhaust to heat the water up for the motor, not to cool the exhaust
you want the heat in the exhaust gas to increase the gas velocity due to maximum expansion of the gas. same theory as HPC style coatings keeping the heat in, and helping spool times.
I'll ask him, these are on race boats so im not sure about keeping water temp up is required, nascar donks make a bit of heat but I'll check it out.
The only area were it was double pipe was the header pipes to the collector, yeah your right hpc coating mantain temp and reduce heat soak
Edited by The BOP
boats pull in river water which is cold, unless you have a heat exchanger system they use the exhaust gas temps to heat the water so your not running cold water through a hot block - stops them cracking.
Makes perfect sense, although the boats ive seen them on are factory, and use a heat exchanger !?!
hmmm
do they still make water exit into the exhuast system? might be a newer design as the older boats i've worked on just had water entering the exhaust pipe after going through the motor and the waters shot out the exhaust pipe in the rear of the boat.
  • 3 weeks later...
keep heat inside the exhaust manifold makes more power so i wouldnt recommend having water jackets in ur exhaust manifold
  • 4 weeks later...
Hi guys, just on the water cooled exhaust on boats, I believe the primary reason for this is to run cooling around the exhaust initially to cool the gasses before exiting the boat at the rear through a fibreglass transom. Having fibreglass hulls the heat from exhaust piping has been known to melt holes through the transom. I work in the Navy and the RHIBs we have run a jacket water cooling system much like the coolant system on cars with a glycol based coolant/corrosion inhibitor. This jacket water is cooled in a heat exchanger by salt water and the salt water then shrouds the exhast system out through the transom exhast outlets. Adriano is correct in his statement about the muffling effect of the water shroud in the exhaust system although a lot of boats have underwater exhast outlets too, which muffles them just fine.
  • 3 weeks later...
well i asked Kyle (6boost) and he does says you cant do them by hand, you need a mill with an indexing head at the least.... i still plan on attempting it in some way, dunno how you would get it into a bandsaw though Craved?
hey VB you can make them by hand but milled always comes out better
the one on the left is hand made and the right is milled
just use some dunny roll cardboard to pratice your angles
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
