Hi guys.
Today i removed my engine (RB25DE), and allso my auto gearbox, but now i maybe have a little problem, because i go to 5 speed manual, then i need to remove my parkbrake pedal, to make som space for my clutch, it is noth legal to drive without parkbrake in Denmark, what can i do.!
https://www.sau.com.au/forums/topic/206876-from-auto-box-to-manual/
You need to install a standard handbrake from an R33 skyline. you will also need a bracket, the part number of which eludes me but i'm sure it's in the Manual Conversion thread. To use the central handbrake you need to get a manual centre console, or modify the auto one. it's not a quick and easy job converting, it took me a few months to get all the parts and convert everything.
Hi guys.
If that is your own private garage...I Envy you......
I still have the standard auto centre console in mine: my handbrake is mounted on an angle, but it is squeezed tight against the drivers seat: still works fine, just looks a little strange
Thanks mates.
My best mate own this garage/workshop, he import highpowered engines from Japan, and build them in to other Cars.
I will take a look at my R33 frontcut today, to find the standard handbrake, and try to build it in to my stag.
We started yesterday morning a 9 o'clock, at 12 the engine, gearbox, exhaust, pedals was out, lov airguns :-) Today we will put the new engine with gearbox, HKS cinter-metal clutch back in to the car, and in next weekend, new ECU, adjusting, and then i hope there will be 550 hp.
I will post some pictures later.
Have a nice day, and thanks.
Edited by Stagea Denmark
I want that motor!!!! Looks awsome.
Thanks. mate.
I found out, that there is 2 differend systems you can buy, a little electrical system, pulling the wire when you push a buttom, and another system called "Brake Lock system", normally you use this when you wanna warm you tires at dragstrip, it lock the frontwheels, you can allso mount this onyour rear wheels,i will buy one of those.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
