installed rb20det into onevia
no problems with boost when stock as a rock
now added fmic (custom piped)
solid induction pipe (no floppy snorkel)
hks2540 snail
custom external coilpacks (vn modified)
aftermarket atmo bov
bosh040
safc
single stage bc
custom 3ich zaust dump back straight through
koyo stainless rad
and some more shit that doesnt matter
HERES THE PROBLEM!!!
stock boost so 7-9lpsi no worries with power bla bla bla
when flicked to high boost its fine untill it goes above 9psi, then kinda does a limmiter but not really more like a stutter, so stops making boost and power.
played with the safc to try to counter the ecu running outa map but ive gone to 20 lean and its still does it, its better but still there, i dont really wanna go much more because detonation (although if others are running leaner let me know)
currently set around 13-15 for stock boost since high boost craps out
BUT!!!!!! its on two occasions runs like a f**king rocket and does wat its supposed to no crapping out, boosting to 16psi no worries and wheelspinning all the way there lol until i blew a cooler pipe noth times and back to shit again!
checked every pipe for splits and bends and leaks but no avail, looked at every possible thing but cannot work the prob out
PLEASE HELP! any ideas or even theories please please help i want the ROCKET feeling back thats why i put the turbo 6 into the nonturbo 4 hole!
https://www.sau.com.au/forums/topic/206884-wtf-batman/
hks2540, 16psi, bosch 040.
then stock ECU + SAFC.
no mention of AFM, injectors...
then leaning out to 20 on safc with no mention of "on the dyno with a wideband A:F sensor up it's bunghole".
how about some more info..
has it been tuned on a dyno?
what power did it make and at what boost?
what A:F ratio is it tuned to?
how are the modified external VN coil's being controlled by the stock ECU?
https://www.sau.com.au/forums/topic/206884-wtf-batman/#findComment-3659167
never been on dyno with this setup , no idea of a/f ratio, i been doing all this on street tune
coils are just run from standard ignighter its a proven setup
Edited by Quigga
https://www.sau.com.au/forums/topic/206884-wtf-batman/#findComment-3659207
I don't get it.
even a "street tune" would involve a wide band O2 sensor, a datalogger and your tuning tool (safc)
you'd do a run, check the datalogger to see what a:f mixture is like at what revs, then adjust your singal bender at each rev point to suit.
Are you just going for a thrash, then making a change on the SAFC going by the seat of the pants feel?
that's insane.!!
How can you say you are doing a tune of any sort and not know what the a:f mixtures are like?
https://www.sau.com.au/forums/topic/206884-wtf-batman/#findComment-3659387
I don't get it.
that's insane.!!
all your saying is get a dyno tune?
well if i had enough money to do that itd be done by now! i build everything by myself and do 99% at home to save money hence why im here asking if anyone can help to keep that $$$$ in my pocket not mr dyno mechanic
https://www.sau.com.au/forums/topic/206884-wtf-batman/#findComment-3659436
I was trying to be helpful mate (for once).
you have your rb20 with stock turbo and exhaust etc.
the stock ECU goes about it's business managing it.
you change a turbo, put in 60% more boost than what the stock setup on the stock turbo is, so probably over 100% more volume in ingested air.
then you are "blindly" making changes to parameters via a signal bending device.
you don't see this as a problem?
I'm sorry you don't have the money for a dyno run.
SAU clubs in each state always seem to hold dyno days.
and you can have 3 runs for about $50 on those sort of days.
perhaps you could save up for that.
get one run, look at the graph showing A:F mixture and make adjustments via your SAFC.
I don't want to be judgemental but it seems you have no idea what you are doing (from a tuning point of view).
It's great that you have done so much work by yourself, but it is all going to turn in to a smoldering lump of piston residue if you keep doing what you are doing.
https://www.sau.com.au/forums/topic/206884-wtf-batman/#findComment-3659497
fair enough i get wat ur saying, but WHY has it run like a freaking dream on 2 occasions??
ive got everything to cope with the bigger turbo, just because i dont have a a/f gauge doesnt mean i cant feel wats happening, 5ritch is too ritch and it blows black smoke sets my rear bar on fire and makes all the kids in the street jump for joy, 0 the car runs ritch and stutters at the 9psi point, 10lean makes the car run better but still craps out at this point, ect to 20 when i hit the stutter its cracking like a WWII battlefield
ino how much dyno days are but i thought maybe just maybe its sumthing else
https://www.sau.com.au/forums/topic/206884-wtf-batman/#findComment-3659559
You haven't said what type of spark plugs you are using?????
If you are running 1.1mm gap then this is most likely your problem.
Try NGK BKR7E or BCPR6E(S) (or BCPR7E(S) colder plugs), gapped at 0.8mm
Might be the best $24 you've ever spent on your car.
Fixxxer
iridums its not spark
https://www.sau.com.au/forums/topic/206884-wtf-batman/#findComment-3659565
well, since you've done so much work yourself already it might eb a stupid quesiton to ask, but have you cleaned the AFM?
or have you re-soldered the AFM joints inside the actual AFM?
search for AFM+SOLDER to see what I mean.
Also, iridium plugs don't mean that you don't have a spark issue.
how old are they?
what gap?
what heat range?
and since you have been "tuning" and telling me just above that it has been so rich it BURNS your rear bar etc, those plugs will be well f**ked by now.
Fixxer is correct.
$24 for 6 new NGK BCPR6ES – 8 plugs already gapped to 0.8mm may fix your problem... well.. one of them.
lol.. mate it's your car and your choice... but from all your money saving, it looks like it's going to cost you in the end.
https://www.sau.com.au/forums/topic/206884-wtf-batman/#findComment-3659808
Alittle knowledge can be a dangerous thing...you seem to know enough about what needs to be done but at the same time there are factors which you are ignoring...and you seem to be chasing your tail in this case...without monitoring afrs and more importantly ignition timing (which the safc can't control anyway)...how are you going to get a decent result? Not to mention that a 2540 on a rb20 when tuned well can push numbers in excess of 240rwkw...with the stock afm and injectors and the afm signal bending safc...its gonna end badly...
Edited by limpus
https://www.sau.com.au/forums/topic/206884-wtf-batman/#findComment-3660014
get rid of the safc and just go for remaps... there's limitations when using SAFCs
a remap will perform just as good as a PFC for mild tunes
and leaning out using the SAFC without a wideband O2 is asking to blow your motor.. now that's not saving money thats wasting a few grand.
$400 remap vs $2000 worth of damage.
https://www.sau.com.au/forums/topic/206884-wtf-batman/#findComment-3660035
Mate, I have an rb20 in a 180 and have also done nearly all the work myself.
I have a similar sized turbo, fmic, 3in exh, z32 afm, 550cc inj, ebc, remap, etc
Firstly, welcome to the world of turbo performance. Until it’s tuned and sorted (sometimes even still after) it will be very hit and miss (hence your 2 experience of space flight)
I had iridium plugs in till my tuner said they didn’t work to potential with Nissan coilpacks for some reason (forget the science behind it).
He suggested and sourced some copper NGK B8EGV plugs for me.
I put them in and yes definitely “the best $24 ever spent” (although they seem to cost more than $4 each at Repco)
Gapping the plugs is band-aid solution and doesn’t allow them to perform at their full potential (smaller gap = weaker spark). It is better to get a plug designed for the application.
Not saying plugs will solve all your problems but is definitely worth a go and worth the money.
Also welding a second lug (same as for the standard O2 sensor) in the exhaust and running a datalogger (as stated) when out experimenting with a mate is a good option. Lets you know what is going on and makes your decisions a little less blind.
I would recommend a remap… won’t cost much more than your SAFC. Add some dyno time and you should be sweet.
https://www.sau.com.au/forums/topic/206884-wtf-batman/#findComment-3660119
yea ive ruled out spark trust me ive spent a lot of time researching and testing ignition systems, im running much bigger coils and plugs to suit the iridiums were liek 20 or 30 each and are being used by some serious engines 400kw+, ive definatly got that sorted almost positive thats not the issue
looks like its stock boost until i can afford the microtech or similar maybe just a a/f gauge for the mean time........
i cant help but think its a sensor or somthing because ive never had a car just go magic fast for a bit then not..... anyway feedback still welcome
https://www.sau.com.au/forums/topic/206884-wtf-batman/#findComment-3660234
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
