Mine's Gt-r Breaks Into The 59's At Tsukuba
Mine's have posted a 59.3 around Tsukuba with their full Mine's spec GT-R. Modified suspension, ECU, exhaust, brakes etc.
Mines’s have solidly broken into the 59’s around Tsukuba by posting a 59.367 with their modified R35 GT-R. Modifications include full Mine’s Spec III suspension (Sachs dampers, Eibach springs), Mine’s VX ROM ECU, Mine’s Silence-VX Pro Titan II exhaust and upgraded Mine’s brake rotor kit (400mm front rotors). Driving the GT-R was Tetsuya Yamano.
To compare against standard GT-Rs, the best we have seen is 1.01.9 posted by MCR when their car was still standard. Other quick times for modified cars have been a 1.00.2 by Amuse with their modified GT-R.
Photo galleries of the Mine's car in current trim as well as the amuse 1.00 car over at:
http://www.gtrblog.com/index.php?blog=4&am...p;tb=1&pb=1
i guess there would be alot more to come from it as well? Was that time with gutter interior etc. etc.? or did it still have all trim? I still dont think it could break that HKS evo time :teehee:
i guess there would be alot more to come from it as well? Was that time with gutter interior etc. etc.? or did it still have all trim? I still dont think it could break that HKS evo time :P
Standard interior minus seats which have been changed but yeah that saved a little weight.
It will be really interesting to see hwo the R35 goes at the goat track. Big heavy car and constant changes of direction. I iamgine its going to be huge dollars to get them down to the sort of weight that will make them competitive with the R34s and EVOs etc
So. hows this time compare to others?
Anyone got a list?
Standard R35 GT-R best time was 1.01.9 or so.
Z-Tune R34 GT-R was 1.00
Power House Amuse Time Attack R35 GT-R was 1.00.2 in January
Most recent Evo X does 1.06.46
Most recent STi does 1.05.95
There are a lot of other times for cars like Ferrari 430 and 360 CS but I don't know the sources of those times.
Cant compare the two just yet IMO as MINES needs more time to develop the R35, they set the benchmark very high with the R34 though
Couldn't agree more, they set the bar so high with the R34 its going to take a bit to beat it with the R35.
I for one hope they do it and set the bar even higher again :(
Evo did it at 00.54 mark. :(
http://www.youtube.com/watch?v=vElMnlFs028
And wasnt the R34 an N1 to start with? Then on top of that they have carbon boot, carbon propshaft, titanium exhaust etc. So the car isnt exactly std weight. The N1 is already lighter, so all up could be 80-100kgs lighter then a std car.
I woudl love to tap the doors on the Mines R34 to see if it also has carbon doors...so wll be interesting to see what Mines do next to the car to get it quicker then the R34
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
