Some a-hole defaced my car with some kind of paint eating liquid
which just means im bumping my respray schedual forward to ASAP
Just wondering How much i should be paying for a respray
To baby blue and possibly with a pearl coat.
My friend said hes uncle could probs do it for around 1.5-2k
My guess is the cheaper you get the worse it is...
p.s i dont want to buy my own paint and ask them to use it
Edited by Scottay
https://www.sau.com.au/forums/topic/206947-car-respray-costs/
If you were in Perth I would do it for 4k windows out inside out (not the engine bay)etc .
I would have the windows taken out as it only cost around 300 to have all 4 taken out and the rear quarter window surounds are way to close to the panels to get a desent finsh around there .
Price will depend on what you want colour wise inside out makes a difference as well .
Cheap is not always good but nor is expensive
    • Yeh vibrant looks a bit overpriced, but thats the US market in general, they pay $50k for a gtst...
    • It's surprising you say this because talking to someone who headed Toyota's CARB certification efforts and was now working for Mercedes doing similar things he said he never had a case where he found that it was necessary to reduce ignition timing for that reason. Knock limits yes, but never because of in-cylinder emissions profile. I'm guessing between EGR and the number of TWCs modern cars stack in series it's not really a problem. I really doubt the NEO is that big a difference. You get what, EV6 injectors, coil on plug, a cold start valve that works off coolant temp instead of basically fixed time constant valve, and... I really can't think of anything else. Not like Toyota where they shipped first gen GDI in the 2JZ-FSE.  Something I didn't realize is that Japan didn't revise their emissions standards for light duty passenger cars between 1978 and 2000. I'm guessing there's a bit of phase-in, but that explains why 2002 killed a bunch of JDM sports cars off all at once. FD3S, A80, S15, Z32, R34, Z15A GTO all died off for that reason. And explains how all these cars got away with no EGR or much of anything other than a TWC and charcoal canister for the longest time.
    • 100% agree. Best bet on an RB will be NEO, but even it will be a long way off. Emissions is one of the big reasons car manufacturers went to DBW and constantly variable cams. When cruising, open the throttle right up, but reduce dynamic compression so low, that it's basically an unrestricted air pump moving very little air.
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
