hi all, lately my car has stalled a few times and sometimes, while driving, shut off then come back on..
i had a prob similar to this a while ago and diagnosed it as afm, i fixed it up as the pins came off solder. but last time when it was afm the idle would go crazy and stall all the time.
this time it doesnt, it will shut off or stall maybe once a trip and the idle would sit perfectly on around 650-750..
any suggestions?? does an old fuel filter cause any of this??
cheers
https://www.sau.com.au/forums/topic/206950-car-stalls-but-stable-revs/
sounds like afm is gawn
mine would do exactly the same
some days perfect, other days felt like violent misfire
if you got a powerfc, graph your afm signal and see if it drops to 0 volts
mm havent checked my switch on the clutch.. but yea i think it was afm.. time to get a new one i think.. after i cleaned it out resoldered the pins inside and made sure all the wires were fine, the car ran like normal.. but every now and again it acts up as if its not even connected.
thanks for the help
btw why would i check the switch on my clutch pedal??
