By MrCodZilla · Posted
Quick update team on the build Things done. Installed Diff Brace ( TMR Performance ) Removed Steering Rack and replaced bushings with GK Tech bushings Remove Manifold and replaced Rocker Cover Gaskets and the Spark Seal Tubes Installed 1000CC Bosch Fuel Injectors Installed R35 Spark Plugs ( Pre-gapped to 0.28" Installed Z1 Coilpacks Removed Fuel Sender unit and modified OEM pump to fit the 350lph Fuel Pump Installed Fuel Sender unit back with a Fuel Return system ( TMR Performance Fuel Return V2 ) Setup Fuel Lines that were AN lines and used P-Clamps to secure them to body ( This is needed to make this road legal in NZ ) Setup Fuel regulator Setup Vacuum lines from Wastegate to boost controller ( 3 port mac valve ) Wired boost solenoid to the EVAP sensor ( Behind manifold of car ) - Polarity of cables doesn't matter Setup BOV and Fuel Regulator lines Installed both aftermarket Aero Fenders ( Sourced from Japan ) Received Impul 280km/h Speedo ( Sourced from Japan ) Installed Carbon shift console Drive down the road untuned without creating boost pressure to test for leaks ( Video attached ) Setup JRP Racing 14in1 Gauge with Boost pressure being monitored Buttoned car back up and Tow to tuning shop in the mighty DE ( Nissan Elgrand E51 ) - VQ35DE Tuning platform is EcuTek and am hoping to 550WHP ( Dyno day is 9th and 10th of October ) Had Shop weld in a new Exhaust piece to connect Downpipe > Motordyne Resonator and to add x2 02 Sensor bungs for an AFR Gauge that will hook into the JRP Multi-Gauge 20240927_181518.mp4 20240927_181618.mp4 20240928_192844.mp4 -
It's in the bloody domain name twice! Yes...the GTR boxen have, for some reason, been cheaper than the RWD boxen for a long time. 10 years ago the GTST box was available here for <AU$3k. 5 years ago the GTT box was available for ~AU$3300. Both retail through 3rd party. Now the GTT box is >4k locally and only available for less if you're willing to jump through some hoops. Apparently they can be ordered from Nissan dealers for $3-3.5k at trade pricing. A friend of mine has a new GTT box sitting on his showroom floor that I keep wanting to hit him up for but I'd somewhat rather he sold it to someone else at his asking price than to me for a mate's rates discount.
I like the 'Beatles album cover, but with bird' element of this photo as well, haha
Hi Gents, Someone I know (experienced engine builder) built an engine. It had some chinesium rods that came with ARP 2000 bolts. One failed on the dyno, destroyed the whole thing. The only possibilities are: Installation error. Possible, but we should discount it almost 100% because he knows what he's doing. He doesn't discount it that much, because he's being hard on himself. QC/QA problems with ARP products. I'd like to discount this, but I have heard a number of stories about similar failures, and stories of some builders buying 2 sets of everything, x-raying everything, and picking only those bolts that they are completely happy with. This behaviour coming from anecdotal stories of ~1% failure rates. 1% of all rod bolts failing would be about 1000x higher than I would expect to be anywhere near tolerable. If I were ARP I certainly wouldn't even be selling the product if they were dying at that rate (for non-installation error reasons). So, I would prefer to discount that possibility too. Fakes. Specifically, fakes being sold bundled with cheap rods sets from CCP factory B in Shenzen, or wherever the stuff is being made this week. So the question here is, does anyone else have some horror stories that would point to fakes being circulated in this manner?
