Am looking at fitting the Apexi Power Intake to the Stagea which runs the R33 GTR RB26. The kit comes with the two pods, brackets and bolts, twin cast AFM mounts etc. Will i need anything else to hook this up?
The reason i ask is that i have no got the car yet, and haveing never had a 26DETT before i was concerned about whether it runs 1 AFM or two, one for each turbo.
Quick response from someone who has one would be fantastic. Also, for the $300 or so it will cost me, is this a good value mod for a can running fairly standard but with a highflow cat and cat back exhaust, FMIC and 12PSI?
Looking to upgrade the computer, coilpacks and turbo's at a later date also, as well as finish the exhaust from the turbo back.
Cheers guys..
Cheers guys..
The RB26 definately has 2 AFM's - one for each turbo inlet. I don't think you would notice a huge difference between a stock airfilter box and aftermarket pods running 12PSI. I had an ARC induction box (aluminium) on my 32 GTR when I first bought it. Ran a 12.4 with that on 15PSI then changed to twin pod filters and ran the exact same time, dynoed at 215kw at the rear wheels. You can safely run 15PSI on an RB26, so maybe a digital boost controller may be the go as well.
I'm also picking up a 260RS (hopefully tomorrow), and after test driving it I really can't believe it feels the same and handles the same as my 32 GTR - can't wait to run them side by side!!
http://www.sinergymotorsports.com.au/displ...um=23&pos=4
Regards,
Craig.
maybe stick to a hi-flow panel filter until you go further
ie bigger turbo's, bigger afm's, bigger injectors, Power-Fc etc
I think its more of a "what do I like best" kind of mod
you'll hear more induction noise from the pods
however the filter should pass thru as much air as the pods (in the 260rs current form)
at this stage of the game, comes down to the $$ you are willing to spend prior to chasing bigger HP.
pehaps that $ is best put towards a clutch atm?
do you like the sound of massive induction roar?
etc
I would be scared to push the ceramic exhaust wheeled turbos past 12 psi! They tend to de-laminate and shatter, with the possibility of ceramic dust ending up in your combustion chamber, or best case clogging up your cat.
I'd wait until you get some steel wheeled turbos on there.
Fair call Paul, running anything over 12PSI is of course a risk - but just for your info, I've been running 15PSI on my '93 R32 GTR since I got it 5 years ago and I've done 55,000km's and about 100 drag passes in it. Never had a problem with the turbos.
Yeah luck of the draw! And knowing my luck.... Are you sure yours are ceramic still? Good to hear they have held together. Love your new 260RS btw - engine bay is neat as - hope there are still a few around when i need me a wagon.
Stagecoach - when you are fitting the kit try and set the brackets up to make sure the lower AFM is not leaning against the intercooler piping (the one with twin turbo written on it). I have a hunch that vibration from this pipe contributes to problems with the AFM - namely this one http://www.skylinesaustralia.com/forums/Fi...-s-t113284.html
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
