cheers for the advice
just looking at the dyno plot, the torque curve drops off at 4100 rpm
where as the manifold pressure doesnt riset above boost pressure till 5000rpm
how do you explain the torque dropping off before the pressure (restriction) rises in the manifold.
Im not trying to discount anyones theories - i welcome them.
But i would like to be certain before spending anymore time and money on this bloody car.
cheers rob
  • Replies 50
the way im looking at it
everythings looking good up until 3750rpm.
at around 3750rpm your gate starts to open.
by 4000rpm its fully open and the interference with the ehaust turbine starts to cause turbulance in the housing. this contnues to build.
by 5000rpm the exhaust wheel has lost a tonne of speed as the gasses are trying to split between the gate exit and going out thru the wheel
due to the turbine slowing down the manifold pressure starts to rise higher and higher.
which only compounds the problem and hence why your torque dies in the ass.
not sure what a non gated rear housing is worth but i would assume not a lot.
and getting your manifold builder to install the gate into the manifold would be a simple procedure.
lowering your exhaust manifold pressure is a must and you have the dyno sheet proving its out of control.
so switching housings is the only way you will fix your issue.
  • 3 weeks later...
we now run the wastegate from the turbine housing where possible. I understand you feel its dodgy, I think the exact opposite, I'd PREFER to run it off the turbine, and do so on my own car, everyone of my friends cars, and any customer that will listen and let me do it. You have better boost control, more hp, faster spool,
6BOOST
Just a quick update, finally got the ecu back with the starting problem patched up (some interference/noise from the idle controller so the dealer just turned it off)
Anyway run it up on the dyno again checking the timing manually found it to be drifting around 10 deg or more under load. Called the dealer to check all settings ie sync falling edges etc. Could not get it stable.
Quickly tried a untuned motec - dead stable.
So ecu is back with dealer.
Has anyone had problems with these TF electronics plug in autronic ecus before ???
Cheers
rob
Imo, the 2nd manifold looks good + iv seen too many spastic 9sec street VL's running that style of gate take off to remember, to think its that. Many ppl swear by that style.
10deg variance under load? that surely could be your issue. Thats a fantastically huge fail from a piece of Autronic hardware. Many a car would go bang with an extra 10deg thrown in at redline and wot.
I blew a wad over your dump / exhuast setup btw man, looks fantastic, love the gentle flare off the back :P
dude, that hole is the size of the waste gate on mine....lol
also noted your CAS is almost cranked right around to fully retarded....recheck your base timing.. .
and if that head is the R33 vvt head you might want to ensure the vvl is working aswell as the rb30 blocks dont cater for the
extra oil gallery..
Edited by nizmonut
  • 1 month later...
How recent is the Autronic? The earlier ones had big issues with the standard CAS and required a change in the internals to give clean trigger signals.
Cheers
Gary
Ahh, version 1.07 from memory, yes it required a change of the trigger disk. (recent versions do not)
Ive finally got a bit more power but its still not all there. :miner:
Ill run through when has happened since last post.
1. Dealer changed some settings and ignition modifiers to stabilise spark timing (on different car as we are not in the same city)
2. Spark timing on my car STILL changing with revs, so took car to dealer and after 3/4 of day found the problem to be the spline in the cam that drives the CAS was missaligned causing a nasty vibration. Aligned as best we could but still a 2 deg shift at 3000-3500rpm.
3. Fixed a few issues - seated injectors 4mm deeper, sealed a hairline crack in the inlet manifold that was causing crap idle, replaced dead alternator.
4. The big one, checked the cam timing again with degree wheel and found in and ex to be 7 deg out. Retuned (road) with correct cam timing and got another 15% duty cycle, now up to 65% on denso 720cc injectors at 21psi. Therefore approx power 280 - 300kw.
The exhaust manifold backpressure is still 2 to 1. ie over 40psi which i really need to sort out.
Next plan is to try another turbo wastegate setup - as soon as i can find a donor...
Unfortunately speedo drive has sheared off and gone through the gear box so ill have to sort that first. Choice.
Ill let u kno how i get on, any ideas on the backpressure would be great.
cheers
rob
Edited by roba
  • 8 months later...
    • Front wheeled vtec powered rb monster
    • Looking forward to the build thread!
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
