My 32 gtr makes a wierd rattle/hum/buzz kindof sound when i put down the passenger window
It sounds as if its coming from the rear passenger side wheel,
asked my mech to look at it but he said nothing about it, prob didnt check it at all :P
has anyone experiences a similar noise
or have any ideas as to locate it and stop it, it annoys the s#!t out of me!! :rofl:
https://www.sau.com.au/forums/topic/206984-gtr-rattles/
Road speed dependant?
Engine speed dependant?
Gear dependant?
Can a passenger hear it?
Constant, or changes with angle of wheels?
Can it be heard by a friend when you drive past them?
Does the car have to be cold (ie mornings) when it does it? Or all the time?
I find that 50% of the time my audio guy finds rattles/sounds that my mechanic can't, he knows I hate rattles etc.
If you can repeat it reliably, take your mechanic for a drive to show him.
If the sound happens when the car is just coasting out of gear, that's the easiest to hear, because less noise in the car.
I sometimes get my brother to get in the back and hold his hands against things until rattles stop, then I at least know where to direct my audio guy.
Hopefully it's not a mechanical problem, and just something cheap like noisy trim.
https://www.sau.com.au/forums/topic/206984-gtr-rattles/#findComment-3661906
can only hear it when the passenger window is down
generally it happens approx above say 40km/h
and you can hear it more when no throttle, but still rolling in gear
i suspect its a vibration of some kind
the passenger in the car can hear it and they suspected the rear wheel
but i cant seem to see anything loose or snythin
https://www.sau.com.au/forums/topic/206984-gtr-rattles/#findComment-3663671
I wouldn't think a tonal resonance from having the window down, is going to make your wheel create a noise :rofl:
A few different trim panels terminate and fasten near the rear wheel arch and C pillar. Its most likely one of thems. As Insomniac said, get someone to press panels with the sun roof down, locate then fasten.
Edited by GeeTR
https://www.sau.com.au/forums/topic/206984-gtr-rattles/#findComment-3665456
ok
i was trying to suss this out today
i took the rear wheel off, and nothing loose or anything there, and i banged it around to see if there was anythin inside that could be rattlin
then i got a mate to drive and i opened the pass door and hung out trying to locate the noise
it definitely comes from under the car, souns like its coming from near the back of the side skirt
we even went as far as filming under the car to see if anthing was moving around, and could not see anythin in the foorage :D
it appears that some of the heat shielding may be loose, but thats toward the front of the car :D
maybe its an excuse to get a new exhaust system, i think there may be somethin in the exhaust making the noise????
anyone??
https://www.sau.com.au/forums/topic/206984-gtr-rattles/#findComment-3667026
"Heat shield and exhaust rattle caused by opened window?"
Iv missed the correlation; no way, can i imagine that occurring.
I still think it can only be pressure, or pressure oscillations (resonance) doing it. Many cars have vents from the boot space to behind the rear bar (right behind the rear wheel) If pressure is trying to equalize in that area, maybe there’s a panel, or rear bar movement.
I'm massively interested now to find out what this noise is!
Keep persisting!
https://www.sau.com.au/forums/topic/206984-gtr-rattles/#findComment-3668111
kindof like a humming/buzz noise
i suspect it may be loose sh!t in the sideskirt
but i tried to unscrew it but i think they are glued on also :D
are you sure it's not the wear indicator spring tabs on the brake shoes that are catching on the disk because the pads are worn mine was doing it on the rear of my gtr it was driving me crazy they are meant to make an annoying noise to alert you ...i took me ages to find this out
https://www.sau.com.au/forums/topic/206984-gtr-rattles/#findComment-3706711
  • 3 weeks later...
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
