ey all
im looking at buying a mid to late 90's stand up jet ski for jumping in the surf. wonderin if anyone knows much about them as to what i should be looking for as it seems there are a few options. also wanting to know what sort of $$ are involved rebuilding one myself and how much of a pain it is or can be. going to spend around $2500 give or take
any other info would be good too!
cheeeerz
brett
https://www.sau.com.au/forums/topic/206985-stand-up-jet-ski/
rule 1. ANYTHING to do with water and engines costs alot of money just in maintenence.
rule 2. An engine which is constantly reved to the shithouse and thrashed will cost even more
People dont cruise around on them, they are constantly wave jumping, doing "donuts" and basically just bouncing off the limiter, and even though they are designed to take punishment (and they do take alot), they are very very high in maintenence. Stay away from the stand up style jetskis imo, they are a pain in the ass to use. The sit down ones are alot more fun and will wave jump very well.
Also i wouldnt really recommend buying one for 2500 (assuming you want that with a trailer), thats on the lower end of the market and your going to get one thats done alot of work, and you will end up spending alot of money. If your handy with the tools you can do most of the work yourself, but parts alone are much more in comparison to car parts.
My brother and i have a mid 90's seadoo that we got about 7yrs ago which came out with a shitty 650cc, we have since replaced that engine with a 750cc and rebuilt it once and it now needs another (we let it sit too long and it seized). When they are going they are alot of fun, but its definately not a cheap hobbie. If you were going to get one for the 2.5k mark, have at least that amount again in the bank ready to spend if need be
good luck :)
yeah sit down ones dont interest me at all mate, too many people have em and i want something different. looking at the prices of em $2500 will get say a 97-98 model 550 or 650. the maintanance side doesnt worry me too much as i have workshop setup with all tools and my g/fs old man owns a bike shop so can order any bits and pieces i need cheap. im planning on doing a rebuild pretty much straight away for peace of mind but when im buyin one there are things like stainless impellers and ride plates etc which im not sure about. might have to bit more research before buying one but does it sound like im on the right track or save bit more before buying one and get say a yamaha 2000 or above?
thanks heaps for the info buddy
brett
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
