R35 Gtr At The Drag Strip In Perth "first Run Was A 11.6"
Guest
 Share
If you go down to the drags tonight in Perth for whoop ass Wednesday you will see a Black R35 GTR having a go and for the people who cant be their it is being filmed and I assume a movie with times will be on Youtube later tonight.
I will post the time when I find out as the person driving knows what he is doing so it should be good.
Edited by Guest
  • Replies 96
Posted Images
11.6 with the speed cut kicking in before the end of the quarter mile.
I think you just made a lot of new r35 owners (well, on order anyway) very happy
Vids? Time slips?
Same think happened with his EVO 8 MR and one of the EVO forums who know everything, someone stated he posted a quick time off the show room which turned out to be quicker times then what the UK were doing and all of a sudden we in Perth were all lairs,
thats cool - how come then NIssan list "11.7s" as their time rather than lower..surely if Steve Jones hit that time, there must be professional nissan testers able to run quicker/similar times.
Just keep in mind running times at a strip compared to using a system like a Correvit style system that most car companies and magazines use will always net a different (read: faster) time. See, at a strip, timing doesn't start until the timing beam is broken. With a hard launching car like a GTR or Porsche turbo etc you'd probably already be doing 10 - 15 klm/h by the time you break the beam, hence the "quicker" dragway times. Correvit and GPS based systems start timing as soon as the vehicle moves.
Regardless though, that's a fantastic time for a stocky :yes:
Regardless though, that's a fantastic time for a stocky :)
Aha!
You read my mind!
Track vs GPS!
Different advantages/disadvantages...
In some cases traction can even be more limiting at a particularly sticky or slippery track, thus affecting launch, and ultimately slip times! The launch control systems are designed to balance wheel-spin with grip. Tracks can throw these systems a 'curve ball'!
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
