I was talking to Richard from www.are.com.au the other day and he told me something that is a bit disturbing....
He has a R33 gtst that he has been working on and finally got it back on the road. Took it to the dyno and made a power run, the result was a bit dissapointing and they were trying to figure it out when the guy asked Richard what fuel he was running. "Optimax was the last fuel put in the car" Richard replied, "When was that?" the dyno opperator asked, "About 2 weeks ago". the dyno opperator then explained that Optimax is only good for about 1 week then its RON rating starts to fall. So he tipped in some octain booster and then ran the car again and made just under 20rwkw EXTRA once the RON got back up. This explains why on a number of occasions after doing a couple of weeks work on my car the dyno runs have been down on power and the car detonates easilly.
Cam
https://www.sau.com.au/forums/topic/207-more-bad-optimax-facts/
PULP [Premium Unleaded Petrol] is different to Optimax and Ultimat as it has a lesser RON that these other fuels.
It seems that the consensus is that BP Ultimate is better than Shell Optimax and even tho it all comes from the same place BP & SHELL have it mixed to their own specs and it seems that BP is better at producing consistant RON readings and lasts longer at a higher RON.
Cam
I've had problems with optimax twice now...I've found it more to do with the actual petrol station than the optimax itself...
The shell on para rd, just past stanmore maccas is the worst!
Do not buy from there...I know plenty of people that have had bad fuel from there...I've had to have my system completely flushed and my injectors ultrasonically cleaned coz of them!
  • 3 weeks later...
Guest Miguel
I just used BP Ultimate for the first time last week, and by my seat-of-hte-pants testing, I feel that Optimax is better. I'm sure I heard some slight pinging with the Ultimate at higher revs.
That said, I know of an Evo & an Sti that required rebuilds due to some sludgy residue left in the fuel filter and Optimax was deemed responsible.
Guest Miguel
  Quote
ive got r33 and have always run ultimate, is it worth putting in an octane booster as well or is that just too much. if i do put in a booster as well is the timing sweet how it is?[/quote:bc23bd7840]
I find with Octane booster & Optimax, my car revs much more freely, it doesn't feel restricted up high. I spose with a higher octane rating, you could fiddle with the timing if you wanted to, to get even more out of it
steve, all the vp fuels with a high ron do contain lead which is a shame. i'm sure the cat or your oxygen sensors will not like you using these fuels at all.
don't quote me but i remember hearing that c-10 is ok to use. again, don't quote me.
i posted the vp's as a point of reference for john.
  Quote
Optimax and Ultimate are not PULP[/quote:da32e47ddc]
'course not. BP manufactures the pulp and sells it to everyone as a raw product. they in turn mix their additives which make it 98RON. it's like you putting in an octane booster in with your fuel but way more technical
it just makes cars more resistant to detonation, that's all.
We have been using Optimax since buying the car last September and never had it ping and I Snot it big time!!!!. I really do give it a hard time.
We are standard apart from 5 Zigen cat back. We have used an Octane booster once and could see no difference at all,,, actually we used it on the Canberra run. I have used the Synegy once and it was no better, then again it didn't ping either. After doing some checking,,,Mobil says there's is guaranteed 98 and Shell is around 96....Stuffed if I know,,,,but I'm sticking with Shell at the moment.
We have a station 5 minutes away and racing the guy next door with his Commadore running 350kw's at the treads on full tanks is a ball. You can hear me now,,,Get out of my way you sideways dickhead.....What you can't stop,,whats wrong buddy,,,Oh thats right is a Holden.
Neil.
  Quote
We have been using Optimax since buying the car last September and never had it ping and I Snot it big time!!!!. I really do give it a hard time. [/quote:b3222afdc9]
Neil, your car has definately pinged, you just don't realise it.
Unless you have a sensor you can't really tell how much detonation goes on.
Nah Onarun,,,,I think,,, at my ripe old age I know if she's pinging or not. I don't think I really need a gauge to tell me that,,,turning the stereo off and listening to her reving to full song under load is enough evidence for me. Remember I'm basically stock,,,which means tons of fuel. I'm with you Shell,,,,the Mobil is also only down the road,,, used a tankfull last week and noticed no difference. My ultimate test will be tomorrow night when I get my neibour with his hot Commadore using Mobil..............
Oh and by the way,,,,,C10 and Cats/02 probe/Cat Heater are like,,,,shit I hate you and I'm gonna stuff you up big time. Don't use it!!!!!.
Neil.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
