  • Replies 66
Are there any more details about this?
I seem to recall seeing a flyer somewhere in here but had too many drinks in Fiji to recollect accurately.
Edit. I didn't allow the page to finish loading up. The flyer was in the post above mine. :)
Edited by writeoff
For all those people who have something else to do, don't ever complain about not having a place drag your car or the fact that there hasn't been a top fueler run in the state for over 8 years. Since i moved to Adelaide from the country (1999) Bob Jane has held the performance community at ransom and now that we have chance to change things people have other things to do??????????????????
There won't be another rally if this one isn't a success; in fact i would almost say that if this isn't a success then it will kill the project in the water. We need the government to supply land for this to go ahead and if we get 20,000 people there then there is a chance that it will happen, but if we have 1000 people there (which i suspect is going to be the case because people have things to do) then the government will tell us quite rightly to go away as there isn't enough public support.
Edited by D_stirls
Are people taking there cars??? i was going to come in the GTR but then thought its right out front of a cop shop and they may not be to happy about us being there so they may get the defect stickers out???? or am i being parinoid??
is anybody meeting anywhere or anything i would like to meet a few guys and drive together
my thoughts also Darren ive sort of been tossing up with the idea of starting a thread but didnt want it to have 150 views and like 2 posts
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
