it was a huge turnout, even if light on from SAU.
If you didn't go, send an email to your local MP and tell them you want a track here in Adelaide. Its good for the econnomy, brings visitors to the state and reduces antisocial behaviour on the streets.
  • Replies 66
I didnt even think to read on here for the SAU meetups before I left home today, oops! BUT I was there 12:00-1:00 and signed the petitition.
I heard the initial speaches from Mike&Mike (MCs for the event) Mayor of Port Adelaide, ANDRA chief, CAMS representative, Anna (main organiser) and Roco (major supporter) and they all had excellent things to say. State Government Rep for Port Adelaide has been pro-active in providing talks at a federal level to help obtain support and funding, and its all looking reasonable at the moment, however the event today would definatley have had a positive effect.
Seems fair to say there is Business, Council and State Govt support for the facility, just need some more federal support and should be all go!
Yeh sorry i didn't get on here before the event, Have no net at home and wasn't at work......
Saw a few of you guys down there briefly(Pete, Steve, Matty and Guy) but had to bail, was good to see some of those old school drag cars down there and Wongs beast!!
It was one thing to just rock up but another thing to sign the petition, and i hope everyone did that!!
Couple nice Senna prints in the art gallery also!!
Edited by Deluxe
dw Darren it wasnt about who stayed the longest or got there first it was about signing the petition
the heat was dredfull we only stayed about 1 hour had a look @ some dragsters chat with Pete , Luke Matty Guy some dude i wasnt sure who he was came up with guy wearing a SAU shirt with no member name??
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
