hey guys im having problems with my r33 with slightly tuned rb25. it has an autronic and the other night it cut out. iv done some research with the error codes and this is what i have.
2 - 2 / long pause / 1 - 3 / long pause / 4 - 3 / long pause / 2 - 2. i have found out that the 13 is the throttle sensor which i think is an old code because for some reason the screws fell out and the car ran rough. the 22 is coolant sensor and i just pulled the plug out so maybe that before but i noticed the 43 is sync engine detected something while running. my car isnt starting now as the crank angle sensor isnt getting power. would this be due to the computer maybe not letting it because of the error that it has detected and may need to be fixed and cleared to be able to start back up.
i know nothing about autronic ecu's or any ecu in general lol. but i have looked through forums and can not come up with anything. any info would be greatly appreciated or if u could point me in the right direction.
i think its time to load her on the trailer and take her to hyperdrive yeah
https://www.sau.com.au/forums/topic/207016-ems-problem/
try replacing the crank angle sensor wit a mates r33 sensor..
heard of a few of these failing..
but it is a rare issue..
also could be wiring...
plus get a new ecu..!!!
why did u rip up out the coolant sensor plug aswel??
and for the tps...put a new screw in there...
that could be another problem..it could be adjusting out ur throttle..who knows
but dont think that has anything wit ur car turning over...
but no harm trying...
clean it out..
mayb an auto elec. could help...
https://www.sau.com.au/forums/topic/207016-ems-problem/#findComment-3664757
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
