Hello all.
I am so angry I cant find the reason for this so I'm offering a reasonable reward for the soloutiion.
I have an R33 GTS-T and a massive flat spot at 4500 rpm until 6000.
I have replaced or changed:-
ECU
New Coil packs (for splitfires)
New Iridium plugs
AFM
CAS
Ignition amplifier
Knock sensors
The diagnostics say the ignition retards to about 5Deg at 4500 rpm and then goes back to normal 15/17 deg at 6000. Obviously during this period its running rich, so any ideas?
https://www.sau.com.au/forums/topic/207039-r33-gtst-flat-spot/
Sorry, I've only had a skyline for a week and I just thought the Aussie club would offer better advise than our UK forums.
The car is completely stock except big bore front pipe and de-cat pipe.
Is the problem likley to be the boost solenoid?
Regards
Regards
does it just sound like its missfiring then clears its throat and pulls fine through the rest of the rev range?
Thanks for all your constructive replys
Yes it stutters at 4500 and then at 6000 clears its throat and bang....BHP up to 260
I've replaced the o/e ECU with a standard unit
The plugs are greddy
Standard boost
Ignition retards to 4 or 5 deg at 4500 and then goes back to 16/17 at 6000
The voltage on the AFM goes off scale at this RPM but the turbo pipes have been checked and no leaks found.
I'm buggered......
I appreciate I can change the ECU to a Power FC but Nissan didn't design the car to run like this so fitting a power FC will only mask the problem and no diagnose the reason.
it won't 'mask' the problem... it will FIX the problem. The problem is your ecu - the standard nissan ecu is the problem. as covered many times it has factory protection wirtten into it which retards the timing and richens the mixtures when airflow exceedes a certain amount. you obvisoulsy have higher boost than stock to make 260hp, what boost is the car actually running? A power fc is a full replacement engine ecu not a piggy back so thier is no 'masking' so to speak.
edit: do you have a boost gauge or are you just using the standard one? stock should be 7psi and therefore your airflow metre should not be maxing out at this level.
Bean. Nissan designed the car to run exactly how it came off the production line. 3psi<4500 7>4500rpm, no big bore exhaust without a cat. The second you change the exhaust, boost,tubo, fuel pressure etc etc these are things that can potentially harm or in some cases destroy both the engine and the turbo. As mentioned before if boost is raised the cars ECU goes into R&R (richen up and retard timing) to prevent high cylinder temps and detonation which occur when outright power is sort after and none of the supporting systems are considered (AFRs, intake temps, injector duty cycle etc etc).
So to sum up, installing an aftermarket ECU or having a tune done is not masking the problem, it is simply getting the most from what you have SAFELY! the factory tune isn't designed for outright power, its a compromise between power, economy and longevity and by running the way it does its saying something isn't right I got to save myself and so the extra fuel goes in and the timing gets pulled out of it.
Cheers.
AFM should read up to 5V i believe before maxing out (correct me if wrong) it may be 5.2V - Get a Power FC and a Z32 AFM .. or set ur boost 2 10PSI and dont touch it.. my series had the same problem for about 2 years... try running 14 or 15PSI and it seems fast up to 4500RPM then just died.. Found the car was far faster on 10PSI, now i have a HKS GT3037 Pro S on it.. and at 10PSI with a POWER FC.. all i can say is.. i wish i had of done this 2 years ago..
What you are talking about is called the FACTORY BOOST CUT.
Every member on this forum that has even slightly modified there skyline and upped the boost has encountered this problem
As others have already said, it's your factory computer protecting the car from blowing itself up.
Any aftermarket replacement ECU will make full use of your modifications, piggyback air/fuel controllers will do the same thing to an extent, but nowhere near the level of a stand-alone engine management systems.
Most of the guys mention Power FC because it's arguably the most user friendly ECU, other brands are HKS, Trust/Greddy Emanage, Motec etc. just to name a few... all with various costs and pros and cons.
I have a Power FC in my r34 and never had a drama with it, I liked how it already had all the standard ECU maps like cold start and electrics eg. air con control, but let's you re-write the parameters of the factory ecu.
Any competent tuner can install these systems and effectively fix the problems you've been experiencing.
bahahaha...
but they designed the car keeping in mind that people would replace the front pipe and remove the Cat convertor all together right?
Brilliant.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
