In need of a quality smash repairer. As the same with most, i am in love with my car, but it also holds alot of sentimental value, which money cannot replace, so i need someone who can give me peace of mind that they know someone who will look after her!
I was recently hit by a massive truck (mack semi, no trailer) he decided to change lanes and hit on the right corner (drivers side) of the rear bar, under the lights. At a quick glance it doesnt look like much, but with the force this guy hit me with the car was thrown into the next lane. Upon inspection i noticed that my rear left wheel is leaning in, and the right wheel looks like it is a bit out of place too. When i drove it, it kinda feels really boat-like, and when driving, while im acccelerating and my foot is on the pedal it feels fine, but when i take it off it feels like its like crab crawling, its strange. and also the hicas is going nutso too! Even though she feels ok, I'm quite hesitant to drive it as this car means everythng to me.
Please, can anyone recommend a quality workshop in melbourne? western suburbs if possible. Thanks!
MiColour in Cheltenham will look after you. Mick isn't back at work until the end of Feb though due to personal reasons but be assured he will look after your car 100%. He won't be the cheapest but I dare say he could quite possibly be the best.
TRANSCAR in (Coolaroo/Cambellfield/Broadmeadows area).
I have used many panel shops before but Transcar is the Best panel shop i have been to.. bar none.
Their quality and service is second to none..
Their attention to detail is astounding and literally no car will leave their shop doors in unsatisfactory condition.
And they also do importing and performance work.
Believe me go there and you won't be dissapointed... :thumbsup:
Transcar
7 Lisa Place
Coolaroo 3048
(03) 9309-9930
MANY THANKS TO ALL SUGGESTIONS - MUCH APPRECIATED GUYS !!!!!!!!!!!!!
Primal Garage - West Footscray
Awesome work, awesome prces. Open late and on weekends.
0419 156 142 (Neil)
Hey Nick, lol funny I seen the guys at Primal a few days ago - they were, yep, AWESOME !!!!!!
After my accident as a starting point I went to another well known workshop down in sunshine, just knowing that I could go in there act all 'um i dont know whats wrong with my car' and this guy would feed me with a bit of info to go off. He tells me that my diff is gone and i need a new one (mind you he only looked at it), just because its leaking, I told the guys at Primal, they just laughed and said the gasket for it costs maybe $40!
As the damage from the accident on the body was minimal (only large mark and some cracks on the back bar) the back wheels were crab crawling and the steering was vibrating a bit, I knew there was bad things going on, they checked out my suspension for me, the side that got hit was out by 2, they adjusted it and gave me details for a suspension place.
Just shows what genuine people they are. I plan to do a fair bit of work to my baby soon, and they will be the ones i will be handing over my money to.
Yeah they are honest guys, which is a nice change in the car game. Also you can see that they know what they are doing by the quality of both their cars, check them out if whe you're in there next. Only thing is that ther workshop is a b!tch to find unless you have someone show you the way.
One thing I would suggest is to get your suspension work done by centreline. The quality of cars in that place speaks volumes for their workmanship.
Hope the car turns out ok!
and PM me for details of their sloppyness
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
